Old 17th June 2008, 08:05 PM   #1
Exclamation Peerless xls 10 subwoofer 830452
Hi all,
Can someone please help me with the dimensions of a ported enclosure or a t.l. design of the above sub woofer. My electronics are not so good but i do very well with wood work.
Thanks to anyone that can help!
Old 18th June 2008, 12:27 AM   #2
john k...'s Avatar
see the Peerless application notes
In summary ported:
Total volume: 26 litre
Port diameter: 70 mm
Port length: 930 mm
Tuning frequency: 25 Hz
Or passive radiaitor:
Total volume: 20 litre
XLS slave with 600g Mms
Tuning frequency: 21 Hz
John k.... Music and Design NaO Dipole Loudspeakers. "We have no right to assume that any physical laws exist, or if they have existed up to now, that will continue to exist in a similar manner in the future." Max Planck
Old 18th June 2008, 02:06 AM   #3
MJL21193's Avatar
In summary ported:
Port length: 930 mm
Translation: Go passive radiator. These XLS drivers are best suited for this.
Old 16th December 2008, 08:44 AM   #4
Francec is offline Francec  Australia
Banned
Hi guys,
What is the upper frequency limit for this sub-woofer, please?
Frank
Old 16th December 2008, 10:23 AM   #5
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
I'd keep it under 200Hz and mine is used only to 100Hz. These are used in the Orion for bass duty so pay to check out where they are cutting them off and what order xo.
http://www.linkwitzlab.com/
No longer DIY active
Old 16th December 2008, 12:53 PM   #6
Originally posted by MJL21193
Translation: Go passive radiator. These XLS drivers are best suited for this. [/B]
What does one gain by using the Passive Radiator for this sub? I've always wondered that.
-Paul Carmody
https://sites.google.com/site/undefinition/diy
Old 16th December 2008, 01:14 PM   #7
Did it Himself
richie00boy's Avatar
No port noise or impossibly long vent.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 16th December 2008, 01:40 PM   #8
rabbitz's Avatar
Saves you using a very long port that you have to fit in the box so the advantage is significant in a small box. The smaller the box, the longer the port to achieve a low tuning frequency (Fb). To elimate chuffing by reducing the air velocity you need a large diameter port and the larger the diameter, the longer the port. Passive radiators save that hassle and are tuned with mass added to the cone but they do roll off quite differently.
Going by the Tymphany notes they are using a 70mm x 930mm port and most users would like at least 90mm diameter so the length is going to increase dramatically.... at least 1500mm long and try and fit that in a box easily.
Larger boxes do not have the same problems as with the same Fb the port is much shorter and more manageable. My 830452 is in a larger vented enclosure than shown on the Tymphany site, higher Fb than they used and a different flared port arrangement to achieve a small diameter and short length port.
Old 17th December 2008, 08:24 AM   #9
Banned
rabbitz,
What size is your box? What is the upper frequency on the 830452?
Thanks,
Frank
Old 17th December 2008, 12:03 PM   #10
rabbitz's Avatar
Frank
My box is 40 litres with a Fb=27.5Hz. This sub is side firing with a downfiring port.
It's cut off at 100Hz by the HT LFE output.
Peerless 10" woofers 830452 XLS lei Swap Meet 1 11th March 2010 08:10 AM
Peerless 830452 New Boxed Quad 66 Pre amp ANTHONY2181 Swap Meet 6 11th March 2010 08:07 AM
FS: Peerless XLS 830452 for NaO/Orion (Australia) tktran303 Swap Meet 0 25th February 2009 09:56 PM
WTB: Seas T25CF-002, W22EX001, and Peerless 830452 ngiachin Swap Meet 0 6th July 2004 10:15 PM
Peerless Subwoofer Andy_Mac Subwoofers 26 2nd September 2002 10:18 AM
Page generated in 0.09534 seconds (84.33% PHP - 15.67% MySQL) with 11 queries
