Old 16th June 2008, 06:11 PM   #1
Unhappy Could it be tuned as claimed? (27Hz)
My speaker designer has built a 18.5L trapezoid enclosure for each of my loudspeakers. It has a 8.5cm/3.3" diameter port and the port length is 11cm/4.3". The woofer is the 10" Revelator coated paper. In this enclosure there is a closed enclosure for the mid which is about 1.9L. I think i have to subtract it from the 18.5L to find the actual net volume for the Woofer (The dimensions are internal)
So we have 16.6L.
I used this formula to find where my loudspeakers are tuned...
Lv = (23562.5*Dv^2*Np/(Fb^2*Vb))-(k*Dv)
where,
Dv = port diameter (cm)
Fb = tuning frequency (Hz)
Vb = net volume (litres)
Lv = length of each port (cm)
Np = number of ports
k = end correction (normally 0.732)
http://www.diysubwoofers.org/misc/portcal.htm
So after calculations
Fb=root(1702390.6/((11+6.22)*16.6)=root(5954.80)=77Hz
He claims that it is tuned at 27Hz...
Is something wrong? Is the formula applicable to floorstanders or is it only for subwoofer designs ?
Thanks in advance for any help!
Old 16th June 2008, 09:57 PM   #2
For what it is worth, WinISD agrees with you completely, 77 Hz it is.
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Old 16th June 2008, 10:04 PM   #3
So that means the 27Hz couldn't be the case for that speaker!
He lied ?
Old 16th June 2008, 10:21 PM   #4
badman is offline badman  United States
Custom Title
badman's Avatar
Default Probably not a lie
He's likely just totally incompetent.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
Old 16th June 2008, 10:24 PM   #5
18.5L is incredibly small for this driver. That's like a small bookshelf speaker. Are you that is correct?
~Brandon
DriverVault Soma Sonus Old Driver Tests
Old 16th June 2008, 10:42 PM   #6
My bad! I did wrong the conversion from cm^3 to liters Now it seems too large ....When I asked him he said 30-40liters. Anyway it seems he is doing it empeirical. And when I said that Klang & Ton recommended 60L bass reflex for this one he said "Oh If i do what they say, the bass driver will bottom out or be loose and not tight, due to huge enclosure...,or something like that"
I will do the calculations again...
The dimensions are:
Big base : 39cm / 15.3"
Small base : 21cm / 8.26"
Trapezoid Height: 107cm / 42.12"
Depth : 35cm / 13.77"
Oh it is 112L! Sorry am a noob in stereometry too
Old 17th June 2008, 08:45 AM   #7
I suspect those may be external dimensions, not internal.
FWIW 27Hz tuning with 85mm diameter / 110mm length = 130L.
/sreten.
PPI tuned off! skooter Car Audio 4 24th November 2007 03:08 PM
PR tuned to different freq mashaffer Multi-Way 4 3rd August 2007 01:10 AM
Variable Tuned PR Geoff H Multi-Way 12 6th May 2007 04:39 PM
STR(Self Tuned Radio) with PIC! cassio_lws Digital Source 0 27th March 2005 08:29 AM
Page generated in 0.11702 seconds (73.71% PHP - 26.29% MySQL) with 10 queries
