A curved sided bookshelf style using real 'Jarrah' timber sides and back (only the baffle will be mdf, 1").... is currrently in construction.
Drivers will be Seas ER18 + TDFC, I will try the Zaph x-o for these drivers (his ZA-SR71), baffle will be rectangular and of the same dimensions, as will be cabinet volume and porting, just the shape is different. I think I need to listen to a design from one of the 'gurus' at this stage, just to see where I really stand on sound and listening issues, but I think the driver combination deserves something more special than a 'box' so I'm doing everything I can to keep to John's original design while creating something with a bit of 'me' in it. The construction is actually proving rather complicated, which is fun !!!!! Like, I NEED more speakers. !! DOH !!! . . . now, I'll let you think about how a curved sides speaker can be built out of real timber !! |
#2 |
Steam, pressure and patience ??
Soaking in a mix of exotic and/or toxic chemicals ( formalin and ammonia ) come to mind; before placing in a two peice mould and applying mass. Or starting with a big thick plank and carving away whats not wanted
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING" |
#3 | |
#4 |
Is that like Kerfing? where you cut slits 1/2way through on the concave side?
#5 | |
Just kidding.
Soft Dome |
#6 | |
#7 |
As you can see, its a translam. Next step, cut the baffles then do the top and bottom.
http://members.optusnet.com.au/~grad...arrahspeak.jpg |
#8 |
Andy,
you must enjoy carpentary and has lots of patient.. nice cabinet.. cheers.. |
#9 |
Andy,
I'd like to place an order... regards, Thanh. |
#10 | |
If you are serious, they will be for sale once finished. go email. X-o will be all Jantzen caps and coils, met-ox resistors. I don't know if I will use the impedence compensation LRC though. You are in Perth, ie Jarrah country, so you can probably imagine what these are going to look like once they are all polished up and glossy !! I have to think of a stand design for them. So if anyone has any ideas/pics that might match the style of speaker, that would be helpful. Ideas are always helpful !!
| Cabinet construction tips needed | guillaume | Full Range | 24 | 12th June 2005 04:37 AM |
| Some more info on cabinet construction | Yesfan70 | Full Range | 16 | 5th May 2005 04:17 PM |
| cabinet construction | tenderland | Full Range | 16 | 9th January 2005 02:52 AM |
| housing material for cabinet construction | michael | Multi-Way | 5 | 11th January 2004 08:16 PM |
| Shielding Ideas (Cabinet Construction) ??? | FrankRoss | Multi-Way | 4 | 8th November 2001 12:03 PM |
| Page generated in 0.12226 seconds (81.40% PHP - 18.60% MySQL) with 11 queries |
