#11 |
Here's another graph, from Unibox this time.
I used xmax=6.5 mm per the documentation that I can find. I don't think that the double volume will really help or hurt you that much - especially when you look at that max spl line. I cuts off most of the perceived benefit, except at lower volumes. However, I do not know how loud 90 dB is, so I may be off. Looks like I am going to have to buy an SPL meter if I am ever going to understand all these graphs...
#12 |
BrianGT.
Just keep in mind once you increase the VAS beyond the woofers optimal enclosure requirements, you are at better risk of decreasing your xmax. If your not running your speakers with low power, fine. However, if your planning to operate them within its program rating, you'll run out of linear xmax. Food For Thought. Best Regards,
OMNIFEX |
#13 |
+-3db is just perceptable
110db is *loud* ears are less efficient at lower freqs like below 50hz double ur input power get 3db more sound. if i was designing a sub i wud design it for eg : 110db at 35hz i need to get a SPL meter also. 90db isnt very loud for bass >perceived as being even quieter.. |
#14 |
Banned
Now i have these Cabasse 21m18LB3 drivers and would like to do something with them. does any one have some ideas what i can do with these drivers ? ported sealed open baffle ? Id hate to have them go to waste.
| Matching a sub to a prebuilt ported design | gorvann | Multi-Way | 3 | 11th July 2009 01:19 PM |
| Seas W18, sealed or ported design? | graks | Multi-Way | 0 | 9th May 2005 07:24 AM |
| Ported Enclosure Design w/o Driver Theil-Small Parameters | misterbobman | Multi-Way | 6 | 29th March 2005 02:06 PM |
| Would ported or sealed enclosure be best for this driver in small PA system? | The Paulinator | Multi-Way | 26 | 25th April 2004 03:38 AM |
| driver sensitivity and cheap amps - a design question | amo | Multi-Way | 4 | 30th July 2003 11:23 AM |
| Page generated in 0.08175 seconds (67.37% PHP - 32.63% MySQL) with 11 queries |
