I'd greatly appreciate knowledge/advice on box stuffing.
The situation is this: Ported box using HiVi F10 woofs. Box lined with "eggcrate" or textured bedding foam. LoPass XO (if it matters) is around 350hz. Problem is: The sound is muddy/boomy with nastily smeared honky/bonky lower mid (broadly around the XO region). Boomy/honky/one-notey midbass and below. This woof has highish Q for a ported box woofer... and it sounds like it. QTS=.39 QMS=2.26 QES=.48 I need to tame it. Woof is also a tad higher eff than the mid its crossed to. (so I don't mind loosing a db or 2) On first try at taming it, I OVERstuffed it with lambs wool. Overall, much much better.... but way overdamped and dull. The mid and tweet now have more of an "ambience effect" than the woof... so you can distinguish the drivers (ie: no blend). I know... just take some stuffing out. But.. Upon further listening and exerimenting, taking enough out to get the above right, the original prob comes back... so I'm not getting the right mix of solving the 2 problems. Also, and more importantly, I've discovered that most of the nasty sound is from box reflections bouncing around and comming back out thru the cone and the (rear-firing) port. Soooo.... stuffing enough to kill that, also kills the "ambience" and causes the overly dead sound in the lower-mids/lows. I could sure use some help to get this solved, and preferably quick. It should be said... the over stuffed condition is way easier to live with and not that far off from OK. Thanks much in advance!! Greg |
#2 |
Speakerholic
Hi Greg,
Try removing all but the eggcrate and sticking a sock in the port. Adjust the sock(s) so the amount of material density changes as you take turns listening. If that works, try and duplicate it with the lambs wool. No I'm not kidding. Cheers |
#3 | |
JJ |
| Speaker stuffing | Alex_B | Multi-Way | 14 | 20th November 2008 08:29 AM |
| speaker stuffing substitute | thezaman | Multi-Way | 7 | 26th September 2007 12:30 AM |
| Stuffing the box. How much? | Pano | Multi-Way | 10 | 8th June 2006 11:57 AM |
| Stuffing anyone???????????? | Dannyball | Multi-Way | 18 | 5th June 2004 01:06 AM |
| Stuffing | Roy Lewis | Multi-Way | 2 | 28th April 2004 06:53 PM |
| Page generated in 0.07825 seconds (72.03% PHP - 27.97% MySQL) with 10 queries |
