I'm using Unibox to tune a ported/vented design and want to get more info/detailed descriptions on exactly what to enter for the following:
Physical Vb Aborption Qa The design is with a 38 a Liter box with with 3/4" Sonic barrier on 90% of the walls and additional Acoustistuff both behind the woofers and at the the top and bottom of the (38 inch tall) exclosure. The note for Physical Vb states: "Add volume displaced by driver, port and bracing to get real construction volume". I would think they mean subtract driver, port & bracing ?? What about volume dispaced by dampening material ?? I have had Qa entered @ 35 but don't know how close to real world this is ?? Can someone who has a good understanding of these parameters please respond.... Thanks Todd |
#2 |
A way to put this into perspective is to vary the parameters in question and see how much it affects the outcome. I think you will be pleasantly surprised that it doesn't matter much.
Leave the driver some breathing room with no damping material and as long as you don't stuff the c*r*a*p out of the box and port you will have success.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#3 |
I normally just allow the Qa to be set by the Damping drop down.
Regards, Dennis |
#4 | |
Todd |
#5 | |
If you line the box [with damping material], I would put Qa at 20. You can measure impedance after it is complete and vary Qa, Ql and Qp until your impedance curve matches - then you will know the actual Q's
| Need some Help with Unibox | LetGoMyEggo | Everything Else | 3 | 3rd March 2009 04:10 PM |
| Help needed with Unibox 4.08 | FSHZ:42 | Subwoofers | 4 | 26th February 2009 06:51 PM |
| Unibox | rinx | Multi-Way | 8 | 5th November 2007 05:38 AM |
| unibox | pkgum | Multi-Way | 11 | 2nd July 2006 07:36 PM |
| Unibox Questions | Schaef | Multi-Way | 5 | 12th November 2001 07:19 PM |
| Page generated in 0.08483 seconds (71.42% PHP - 28.58% MySQL) with 10 queries |
