Advise needed!.
I am planing on building a pair of w m t m w D'Apolito design {dual separated by mid/ tweeter section, bass cabinets}. They are going to be sealed bass units, connected in parallel with each other and the bass boxes are going to be truncated pyramids, similar to shinOBIWAN's ARANTISM wich are simply amaising and "inspiring". The problem is, how should i enter that concept in Bassbox 6 pro, in the "box design"?. Should it be seen as a big, single bass unit with dual paralell drivers or, conceive a single "box design" and, transfer it in X-over pro as a double box/ dual woofer unit?. Bassbox can't add 2 truncated piramids, separeted or not, by the m t m section... Hoping my question is clear enough, thanks in advance for your help!. |
#2 |
? TTT ? Nobody here uses a Bassbox pro software ?...
#3 |
Thanks anyway...........................
#4 |
R.I.P.
I don't see the problem. Model it as one box, two drivers in parallel....
| Why Di Apolito | sumsound | Multi-Way | 21 | 12th August 2008 07:25 AM |
| BassBox Pro, prototype ? | REALFLEO | Multi-Way | 76 | 16th July 2008 09:23 AM |
| Views on Bassbox Pro | smithy666 | Subwoofers | 4 | 1st February 2007 11:54 PM |
| more info on d'apolito needed | blu_line | Multi-Way | 4 | 17th October 2002 12:52 PM |
| Page generated in 0.09402 seconds (71.49% PHP - 28.51% MySQL) with 10 queries |
