Old 12th June 2008, 11:24 PM   #1
Default Don't have software, will you run some #s for me?
I don't have the software and if I did I wouldn't know what to do with it!
I'm wondering if I could use these for subs in a regular cab pick-up in 1.0 c.f. each or less and get good bass from them...
Power handling: 90 watts RMS/130 watts max
Voice coil diameter: 2"
Impedance: 8 ohms
Frequency response: 26-6,000 Hz
SPL: 90 dB 1W/1m
Vas: 4.77 cu. ft.
Xmax: 3.0mm
Qms: 4.17 * Qes: .36
Qts: .34
Fs: 26 Hz
I appreciate any and all help greatly!
Brian
Old 13th June 2008, 12:48 AM   #2
Ron E is offline Ron E  United States
Ron E's Avatar
Just download WinISD or some other freeware.
3mm of Xmax is not a lot of excursion. These aren't really subs. They will make noise in your pickup, can't tell you how much without knowing diameter and other parameters...
Without running numbers in a calculator I can give you this estimate: in 1 cubic foot you will have a halfspace F3 ~60z or so, and Qts in the range of 0.8 or so. Your pickup's small cab will bring up the low end considerably, though - so the actual F3 will be lower..
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
Old 13th June 2008, 12:53 AM   #3
I run a Mac...
Old 13th June 2008, 12:58 AM   #4
This is all I know...
http://www.partsexpress.com/pe/showd...number=290-088
Can you work with it?
Brian
Old 13th June 2008, 01:20 AM   #5
Ron E's Avatar
a dump from my uber spreadsheet....
Anything you see about ports on the front page does not apply - this is a sealed box design of 1 cubic foot
F3 62.5 Hz and damped Qts of 0.74
First graph is SPL at 2.83 volts and Max SPL (90W)
second graph is power handling about 10-12 watts at low frequencies - due to low excursion
third graph is input impedance showing typical closed box impedance peak - no surprises here
fourth graph is excursion modeled at 75Watts/8 ohms input - note that it is beyond spec below about 100Hz - see the power handling graph.
5th graph is phase and group delay - nothing of note here.
Old 13th June 2008, 01:52 AM   #6
...not a suitable driver then?
Old 13th June 2008, 01:59 AM   #7
Ron E's Avatar
...depends on what you want. I can imagine $40-80 more well spent somewhere else. Look at a DVC12 or DVC15 at the same website, or a "Quattro", as they call them.
Old 13th June 2008, 02:04 AM   #8
I'd like to thank you for taking the time to help me out. Thank you
Do you have any suggestions with paper cone and rubber surround?
I have 50 to 75 watts available per woofer if that matters.
Brian
Old 13th June 2008, 10:59 AM   #9
It is a decent speaker 10" bass unit with good efficiency 90dB / 8 ohm.
It will work fine in a well stuffed 1cuft internal sealed box but it is not really a subwoofer.
Presumably a 4 ohm driver would be better for an in-car amplifier ?
Why paper cone ? for a subwoofer ?
/sreten.
Old 13th June 2008, 04:07 PM   #10
Thanks sreten
I find that a paper coned drivers sound just sounds better to me...
Do have any diver suggestions?
Brian
pc software rkreim Digital Source 8 10th December 2007 08:01 PM
Free software including DazyWeb Lab software ashok Everything Else 2 6th November 2005 11:31 AM
Software? ManUtd Tubes / Valves 3 29th October 2003 08:15 PM
software junglejuice Everything Else 6 1st December 2002 03:23 PM
Page generated in 0.10170 seconds (85.28% PHP - 14.72% MySQL) with 11 queries
