Old 11th June 2008, 02:17 AM   #1
jjb22 is offline jjb22  United States
Question Event Studio Monitor Problem - Please HELP!
Hi all,
I currently have a pair of Event TR-6 bi-amped monitors and I am having a problem with one of them. As soon as I power the unit on, I hear a loud fuzz/static sound coming from both speakers. It does appear that the fuzz is louder from the tweeter, but that could be due to the nature of the fuzz (i.e. not much low freq. stuff).
When I run an audio signal to the unit at a normal level, if I listen closely (head next to speaker), I can barely hear the audio underneath the fuzz. It seems like it would be something in the signal path before the speakers and possibly before the amps.
I have tried swapping power and signal cables with the working unit, but it did not change anything.
One possible thing that may have caused this is electrostatic discharge. I noticed this problem for the first time after I felt a shock when I pushed on the power button.
Unfortunately, this problem started right after my warranty had expired. I know I could send the unit in for repair, but I fear that the cost of shipping plus the actual repair combined would be close to that of a new unit. That is why I would like to know if there is anything that I can do to repair the unit myself? I do have some background in electronics, so I would be comfortable if you could give me a starting point or have any ideas of what could be wrong based on experience.
I have contacted Event and they gave me the schematic (attached), but had no ideas for what could be wrong.
Thanks in advance for the help, I would love to get back to making music!
Please let me know if you have any questions for me.
Thanks again
Old 11th June 2008, 04:41 PM   #2
The schematic was too big to attach. If anyone would like it that could help me out, I can email it.
I swapped out the tweeters and woofers to verify that they still work, and they do. So that is good! So that leaves the amps, active crosovers, subsonic filter, input amp or power supply.
I have it all torn apart right now and I have given it a good visual inspection and do not see any obvious problems.
Any ideas of what could be going on or some direction on how to troubleshoot other sections would be greatly appreciated.
Thanks again.
Old 8th September 2008, 02:58 AM   #3
I am having the same problem with my TR6's. Did you ever find a solution? Could you email me the schematic?
Old 4th September 2011, 10:50 PM   #4
Sorry to latch on to such an old post; I have a TR6 that started doing the same thing- Low output (maybe a power transistor or power stage issue?). Did either of you fix your TR6's? Can I get a copy of the schematics? Thanks for your help.
Chuck
Old 5th December 2011, 08:52 PM   #5
Default Possible solution to failed amp.
Chuck
I might be a bit late, but let me see if this helps.
I bought a pair of TR8's that were used and one was known to be bad. It had the same symptoms, really low output from both drivers even with them turned up all the way.
Doing some basic circuit tracing and probing, I found that the sensitivity pot had opened up on the wiper leg. I have two linear and two audio taper pots coming in the mail. I'll let you know how it turns out.
Old 6th December 2011, 05:05 AM   #6
Default Repaired TR8!
BINGO!
Replacing the sensitivity pot did the trick. These TR8's are back in the mix, so to speak.
Event Studio Precision Repair zumazon Chip Amps 35 15th September 2010 08:28 PM
Event TR6 monitor noise SkippikS Instruments and Amps 0 7th September 2008 12:18 AM
Event Studio Precision 8 loud static from tweeter coolsat Multi-Way 0 28th August 2008 07:41 AM
once again studio monitor holger honda Multi-Way 17 4th August 2008 04:46 PM
Event Studio Monitors kringe Multi-Way 0 26th March 2008 07:42 AM
Page generated in 0.08944 seconds (79.22% PHP - 20.78% MySQL) with 10 queries
