Soundeasy: how to: Inches not Meters - diyAudio
Old 5th June 2008, 09:06 PM   #1
critofur's Avatar
Send a message via AIM to critofur Send a message via MSN to critofur Send a message via Yahoo to critofur
Question Soundeasy: how to: Inches not Meters
Sorry if this has been posted a dozen times before, but I searched and couldn't find it!
How do you set Soundeasy to use inches instead of meters?
It would really be a big pain to have to convert everything before entering it in!
I don't understand why there's not just an obvious box to check under "preferences"?
Critofur
http://www.ohmspeakers.com <- all the folks here are my friends
Old 5th June 2008, 09:40 PM   #2
y8s is offline y8s  United States
y8s's Avatar
Send a message via AIM to y8s Send a message via MSN to y8s Send a message via Yahoo to y8s
well....
you may find it ultimately easier to "learn metric" at least from a practical use standpoint. can you hold your fingers 3 inches apart reasonably accurately?
Can you hold them 75mm apart?
is the mic a meter away or is it just over a yard?
I bet you could find a tape measure in metric units faster than you'll get metric units in SE.
I know it's not the answer you want, but until you have a real solution, just memorize the conversions. 2.54 cm per inch or 25.4 mm per inch or .039 inches per millimeter. or type it into google in this form:
## inches in meters
it'll spit out this: ## inches = YYYY meters
at least it's fast.
Old 5th June 2008, 09:50 PM   #3
I don't think there is a way to switch units in SE. Besides, almost all driver t/s parameters, dimensions etc. are in metric units anyway.
The only places in SE where I normally have to convert to metric units are the cabinet dimensions and baffle layout, and this is just if I don't remember to design the cabinet in metric units in the first place.
In fact I wish my Jasper jig was set up to use metric units so I didn't have to worry about figuring out what hole is within 1/16" of my driver which is 144 mm in diameter
Dennis
Old 5th June 2008, 10:14 PM   #4
critofur's Avatar
Originally posted by y8s
well....
Metric is easy to use, of course, and, it's easy to remember that 15 cm is approx. 6 inches. (and, as you say, 2.54 cm = 1 inch precisely)
When all the measurements I use (except for some T/S, as Dennis points out above) are ALREADY in inches, however, it's rediculous to convert each and every one first, before I can type it in to the program. I don't want to convert 1 7/8" to cm in my head (of course it can be done, but I don't want to be thinking about conversion, I want to be concentrating on other aspects of the speaker).
It would be great if US (and UK) would switch to the Metric system, but, until them, it's simply unreasonable for software not to support English measurements???
Critofur
Old 5th June 2008, 11:32 PM   #5
diyAudio Moderator Emeritus
Iain McNeill's Avatar
do everything in a spreadsheet, then conversion is a breeze.
Old 6th June 2008, 01:13 AM   #6
You might try an easy converter, like this one. It's free. I use it all the time for with SE as well as Unibox, etc. for distance, area, volume,etc. conversions. It is very easy and quick to use.
Convert
Dan N.
Old 6th June 2008, 02:17 PM   #7
Maybe this will by helpful:
http://miary.hoga.pl/ -convert program
Best
C
Old 6th June 2008, 02:20 PM   #8
six from top is -LENGTh
five from top is -cubature
Old 6th June 2008, 05:47 PM   #9
critofur's Avatar
My table saw is in inches, my router jig is in inches, since everything we do here day to day is in inches, feet, yards, miles, etc., it's easier to think in inches. Boards, tubes, screws, etc., that I buy,all come in INCHES.
When I'm figuring out what baffle size I want, I want to work in inches - type in 7 inches, see the results, not quite right? Let's try 8 inches then... Etc.
It's a lot easier to add the option to a program to choose what units to work in, than it is to use a program where you have to keep converting continuously each time you enter data.
edit: yes, of course there are lots of easy to use conversion web pages, programs, etc, but you shouldn't have to do that.
Critofur
Old 6th June 2008, 07:56 PM   #10
y8s's Avatar
not sure if it's patented, but CAD programs use a fantastic way to convert units on the fly.
Solidworks:
say you're drawing something in mm but have a measurement you want to use in inches. simple. in the entry box you just type in "XX in" and it parses it and converts it for you.
Pro/E:
you can do math in the entry box so you'd enter XX*25.4 for inches to mm conversion.
be nice if SE did one or both.
8 inches paper cone treatments graaf Full Range 65 26th March 2014 07:59 PM
Six inches... Godzilla Full Range 0 31st October 2006 06:57 PM
Copyright 1999-2017 diyAudio
