Old 5th June 2008, 07:07 PM   #1
Tino is offline Tino  Canada
Default How easy of a crossover can I get away with for this Vifa combo?
Would it be possible to get by at lower volume levels with a simple 6db crossover (say 3.5 - 4K) and still have it sound fairly good?
Tweeter is a Vifa D27TG-45-06 http://www.soundocity.com/Oregondv/V...27TG-45-06.htm
Woofer is a Vifa M13 shielded (M13SG09) http://www.madisound.com/catalog/pro...oducts_id=1094
Thanks guys
Old 5th June 2008, 07:38 PM   #2
Lsharptec1's Avatar
Tino,
The simplest crossover would be to operate the woofer full range (no crossover at all), and wire a 4.7 uf to 6.8 uf capacitor in series with the tweeter.
If you hear to much highs, the D27 tweeter may need an L-Pad to attenuate the tweeter level a few db.
Good quality non-polarized capacitors and L-Pads are available from Parts Express at:
parts-express.com
Good luck,
Larry
Old 5th June 2008, 07:38 PM   #3
Yup. That's how most linear phase speakers are done. And that's a good tweeter, it can take it.
Old 5th June 2008, 08:44 PM   #4
thanks guys for the response. So that woofer wont sound harsh on the upper end running full range? I mean within reason of course if I'm not driving it hard....
I've four 3.3uf and two 1.8uf caps branded as "bennic". They are yellow in colour. I dont know if they are decent or not but they do look better than your standard electrolytic metal can type caps. I picked them up long ago for some car audio stuff I was tinkering with.
Can I take one 3.3 and one 1.8uf and put them in parallel for each tweeter? That should give me about 5.1uf. There should be no issue sonically vs one larger cap right?
Old 5th June 2008, 09:22 PM   #5
Lsharptec1's Avatar
Tino,
As Caferacer said, many well know commercial manufacturers use nothing more than a 6 db crossover in some of their systems.
The Bennic capacitors you mentioned should do the job. I have used Bennics several times in full range TL systems that I designed.
The M13 is a very good Mid-woofer, and should have no problems being operated full range, but don't expect deep bass from it.
If you feel the need to give it some additional protection, wire a 0.5 mh air core inductor in series with the woofer.
Larry
Old 5th June 2008, 09:55 PM   #6
Ok fantastic guys. I am going to try this tonight. Actually I think I might even have a 0.5mH coil at home... or maybe 0.4mH. I'll try hooking things up with the cap on the tweeter and nothing else and listen for a while and go from there.
Thanks everyone. Glad that I had chosen some drivers that work well together - by accident of course.
Old 5th June 2008, 11:19 PM   #7
critofur's Avatar
Send a message via AIM to critofur Send a message via MSN to critofur Send a message via Yahoo to critofur
Would love to hear how this works out.
Always looking for a woofer that doesn't need a crossover $36 is a good price for such a woofer, if, indeed, it works well w/natural roll off.
Critofur
http://www.ohmspeakers.com <- all the folks here are my friends
Old 5th June 2008, 11:45 PM   #8
gainphile's Avatar
Hi, I got the P13WH woofer which somewhat have similiar freq. response with yours, very smooth.
I initially run the woofer directly, but it didn't sound right after a while. So I connected 0.22mH inductor just to cut the higher freq. at 6kHz. Now it sounds much relaxed.
For tweeter I use 12db/oct cutting at 6kHz. It's not complicated at all.
Sensivity difference between my Vifa woofer and Tweeter is -2db (woofer is 88db and tweeter is 90db) so I use L-pad to attenuate them.
It sounds very neutral now (but I don't have measurement devices).
http://gainphile.blogspot.com
Vifa P13 crossover Mos Fetish Multi-Way 21 8th June 2010 06:07 PM
Crossover for vifa 2 way setup - how can I find out what this crossover is doing? Tino Multi-Way 11 17th May 2009 04:21 AM
Crossover for Vifa TC14 + Vifa PL27. HenrikW Multi-Way 2 8th November 2006 01:15 AM
Vifa XT Combo??? audioferret Multi-Way 0 3rd December 2005 05:56 PM
Vifa MG crossover design dunderchief Multi-Way 8 27th December 2003 11:00 AM
Page generated in 0.10319 seconds (80.72% PHP - 19.28% MySQL) with 10 queries
