Hi there,
this is an old project of mine, which i'd like to introduce. Since the self developed ribbon tweeter attracted some people i posted some pics of the 2002/2003 project. Cheers Oliver |
#2 |
great work, awesome looking speaker.
is that a port in the side? |
#3 |
Hi rustlabs,
thank you. The slots in the side are resistive leakages. I was inspired by some "Amphion" models from Finland at that time. There are some cloth layers behind the slots ... A reflex port is placed in the back of the cabinet. The mid-bass (Visaton AL 130) is coupled via a small ported chamber behind the driver into a biggger main chamber. That bigger chamber works like a usual BR cabinet. The smaller chamber with port lowers the resonance of the driver simply by adding mass. Above approx. 150 Hz the main chamber is decoupled by the mass load of the inner port and the compliance of the chamber behind the driver. So above 150Hz the drivers "cone" looses mass and efficiency increases ... that is compensated for in the crossover. The leaks in the small chamber introduce a cardioid shape in midrange distribution pattern. This way less sound is radiated to the sides and to the rear. This works only if the sides are not covered. It should be placed freely, even on a shelf. The Bass goes rather deep, as i remember the cab is tuned to approx 35 Hz, but overall efficiency is rather low. Dynamics can be improved greatly by crossing with a subwoofer. So it is no "play it loud" speaker, but to me it was sufficient for most days ... Crossover is at 950 Hz. To that frequency the AL 130 cone does not suffer from breakup and the transition to the ribbon is very smooth and (to most ears) undetectable. It is a fairly complex design, but i think the best is the tweeter. I am currently developing a new transformer for it. For that bookshelf speaker the efficiency of the old transformer/crossover circuit was sufficient, but i want some more to be able to use the tweeter in different designs ... I have attached a pic with top cover removed. You can see the crossover with Transformer (top right), the backward chamber for the ribbon tweeter (it is a dipole if not placed in a chamber, stuffing has been removed partly for the foto) and the main bass chamber with white curved plastic port. Cheers ... Oliver |
| PE 269-570 bookshelf speaker | GM | Full Range | 7 | 18th October 2008 02:31 AM |
| Bookshelf speaker mod | lontas | Multi-Way | 9 | 21st June 2008 05:32 PM |
| bookshelf design around foster ribbon | aleexman | Planars & Exotics | 0 | 19th December 2007 04:06 PM |
| 2-way bookshelf speaker | XizzeriA | Multi-Way | 3 | 9th July 2005 12:53 AM |
| budget ribbon bookshelf speakers | xstephanx | Multi-Way | 12 | 17th April 2005 01:15 AM |
| Page generated in 0.09468 seconds (68.41% PHP - 31.59% MySQL) with 11 queries |
