Making a set of speakers for my father and was thinking of using 2 x Jordan JXR6 HD and 2 x 6x9 inch car bass drivers (firing downwards in a bass reflex cabinet). The bass speakers are dictated by the shape of the cabinet. I need advice as to what crossover to use and what size the sealed top cabinet for the Jordan units should be? Is 200 hz the right crossover point?
Cheers Will |
#2 |
Howdy - the Jordan site recommends anything up to 4 litres for the JXR6. 3 litres is about optimum for a maximum flat response. I'm currently using a 2.2L enclosure for mine and they run to around 100Hz, used fullrange with no x-over (in fact no bass units at all at the moment).
Crossing over at 200Hz would give more headroom and be safer for bass output - the less LF extended JX53s crossed at 500Hz with a 6dB xover. Which car bass units are you using? |
#3 |
Most car 6x9's will not work well in vented boxes as they are designed mainly for rear shelf mounting and have highish Fs and Qts (~ 0.9). http://www.t-linespeakers.org/projects/rune/index.html Something similar crossover wise would work well. Bass box does not have to be a TL but you do need a decent quality bass unit. |
#4 |
If that is like the 6T, a pretty good match for it is the Silver Flute W14RC25 5-1/2" woof Cheers! |
#5 |
Thanks for the advice- I meant to say 2x jordan 50mm units and 1x bass unit per speaker.
As I would like to get a decent oval shaped bass unit and a car unit is not advised, are there any oval bass alternatives? The cabinet design looks great so it would be a shame if i cannot find a suitable unit, the only other option I can see is to ditch the design and use 2 jordan units in a small enclosure with a sub. |
#6 |
Speakerholic
How's this?
http://www.partsexpress.com/pe/showd...number=264-864 Here without the neo mag. http://www.partsexpress.com/pe/showd...number=264-837 They also have an 8 X 12 unit. http://www.partsexpress.com/pe/showd...number=264-838 |
#7 |
say, where did you get the JXR6HD. I thought it is out of stock everywhere...
#8 |
Two Jordan drivers per cabinet ? A small pair of 0.5 ways + active subwoofer is probably your best bet. |
#9 |
With two JXR6s per side the sat/sub idea is a good one. Google the Bandor Pentachord for an example. You could probably get away with using the sealed box to roll off the sats and an active sub - no messing around with crossovers.
The JXR6s are 4 ohms so you'll need to connect in series or run in parallel with a series resistor. |
#10 |
Thanks Cal and Colin-
The speaker links are just what i need and the prices are very reasonable. Thanks so much. Will the little Jordans cope without crossovers? I think they might get the occasional punishment with loud classical. The bass speakers will be firing downwards and won't be visible - If i were to use crossovers what is recommended? around 180? |
| ALR Jordan Entry L Speakers (or components) | dbargna | Swap Meet | 0 | 25th February 2008 12:22 PM |
| Jordan JX92s advice | smallangryboy | Full Range | 16 | 13th October 2007 03:15 AM |
| Early Jordan-Watts Speakers | adunster | Swap Meet | 5 | 17th August 2007 05:56 PM |
| Jordan speakers on eBay | Colin | Swap Meet | 0 | 4th March 2006 12:59 PM |
| Jordan Transmission Line Speakers & Sub | JVA | Multi-Way | 63 | 20th January 2005 06:01 AM |
| Page generated in 0.09226 seconds (84.78% PHP - 15.22% MySQL) with 10 queries |
