Old 2nd June 2008, 10:17 AM   #1
4sfed5 is offline 4sfed5  New Zealand
Default anything better than audax tweeter??
i have some infinity floor standers wihich have audax tweeters(i think) and im looking at replacing them with some audax TW025A0.
can anyone recommend a better value for money tweeter than this audax? many of the vifas are now not available. so any help would be great.
Old 2nd June 2008, 12:59 PM   #2
http://www.madisound.com/catalog/PDF/audax/tw025a0.pdf
Not an "easy" tweeter to work with due to top end rise and the
undamped fundamental resonance impedance peak, the c/o needs
investigating to see if it has impedance compendsation or any eq
for the top end peak. If it does then use the same driver, more
to the point just replace the dome / coil assemblies.
If it does not then probably another tweeter will be as good.
http://www.zaphaudio.com/tweetermishmash/
Seas 27TDFC is possibly a good choice.
/sreten.
Old 4th June 2008, 08:12 AM   #3
the coils are no longer available and hence the need to do a full replacement. just wondering whether or not to stick with audax or get a better tweeter for similar money
Old 4th June 2008, 04:47 PM   #4
badman is offline badman  United States
Custom Title
badman's Avatar
It's unfortunately not as easy as all that. I'd try to get an exact replacement so it works with the current crossover. Otherwise you're likely to get problems, especially if the crossover is complex.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
Looking for Audax TMO25F1 Tweeter. Big_Bill Swap Meet 16 21st September 2009 07:06 AM
What tweeter for Audax PR170M0 ? Thomasjunta Multi-Way 1 23rd May 2008 11:25 AM
Audax ap210 with Kef t27 tweeter fin1bxn Multi-Way 7 16th August 2007 07:49 PM
AUDAX TW025A12 Tweeter??? murat Multi-Way 7 29th March 2005 07:45 PM
Audax PR120IL Tweeter 105dB mozfet Swap Meet 1 4th February 2003 11:37 AM
Page generated in 0.06736 seconds (78.24% PHP - 21.76% MySQL) with 10 queries
