simulated Linkwitz transform?
Old 13th March 2003, 08:32 PM   #1
nobody special is offline nobody special  United States
nobody special's Avatar
Question simulated Linkwitz transform?
I am done with the massive tower of woofers (see thread "my cheap throw-together sub woofer") and I was planning on building a linkwitz transform circuit to get some extension out of the sub. Right now the cut-off (F3) is at about 45 Hz (not very good extension), which is what I was expecting with these cheap woofers. Actually, it's not that bad, considering that these are 8" woofers in a sealed enclosure. Now, for the question:
Since I have a built-in crossover on my receiver at somewhere around 100 Hz, could I use the active crossover on the sub amp to simulate a LT by setting it to 45Hz and boosting the level into the woofer? I am actually doing this now, and it seems to sound pretty good. I was just wondering if I am effectively doing the same thing with the crossover as I would be with a seperate circuit. It is a second order 12db/octave low pass, so it would seem to be effectively the opposite of the closed-box rolloff. I do have more than enough volume. The woofer level is set at less than half, and the receiver level is at -4db, and it is blending very well with my main speakers. Oh yeah, and it will shake everything in the house if I want it to
Old 13th March 2003, 08:41 PM   #2
jackinnj is offline jackinnj  United States
jackinnj's Avatar
you can put a little bump in the response by using a Chebyshev filter -- not maximally flat in the passband.
Old 13th March 2003, 11:14 PM   #3
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Your best bet is to knock up a tunable parametric EQ, I have no links to hand, but a google search should give you some circuits to think about.
This will enable you to tune the bass extension, and with the Q, Boost, and Frequency controls you should be able to simulate most LT responses.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 14th March 2003, 01:08 PM   #4
Morph is offline Morph  United Kingdom
Send a message via MSN to Morph
why don't you just make a linkwitz transform circuit. Its extreamly easy you can get a PCB for it form rod's site.
Old 14th March 2003, 02:35 PM   #5
cocolino is offline cocolino  Germany
cocolino's Avatar
That`s what I thought too.
The LRT-circuit is hard to beat in simplicity and a tunable parametric EQ circuit certainly is more complex to build and more difficult to adjust (IMO).
In contrary to Your idea simply to boost low frequencies, the Linkwitz Transform Circuit would also allow You not only to boost but to have influence on driver-Q or better to say box-Q (speak time response) what might be desirable .
As You have an built-in active x-over already the power supply for the LRT-circuit OP-Amp. is already there.
At least for a try, even no need for a PCB - it`s so simple You could breadboard first and see if it`s worthwhile to implement fixed later (maybe with PCB then).
Christoph
STEAL the BEST - INVENT the REST
Old 14th March 2003, 02:44 PM   #6
So, the popular vote says to build the LT... Thanks guys.
It should be easy enough to do anyway! Maybe a weekend project?
-NS
Old 21st March 2003, 11:18 AM   #7
lubbie is offline lubbie  Canada
Send a message via MSN to lubbie
here is a easy one. punch in the info and it will give you graphs and all.. even capacitor values.
simulated Linkwitz transform?Hide this!Advertise here!
Linkwitz Transform PCB help mikee55 Subwoofers 2 3rd October 2006 09:36 AM
linkwitz transform peace brainerd Subwoofers 4 31st January 2006 01:13 AM
Linkwitz Transform PCB? diydave Parts 2 1st September 2005 12:05 AM
Linkwitz Transform? Aunkst Chip Amps 6 28th March 2004 11:59 PM
Which op-amp for linkwitz transform? Hybrid fourdoor Multi-Way 2 13th September 2003 12:22 PM
