Hello!
I am planning to use MCA15RCY into a 3way system. The system has 2nd order active filter with cutoff frequency of 300 / 2400Hz. Tweeter is SEAS 27TDC. Woofer: Beyma 8BR40N in a closed 55l box. It is possible that I will upgrade filter to 4th order. Anybody has experience with this driver? How it handles 300Hz? I want a "fast" driver. Currently I have Beyma 5MP60N, but it can not keep up with tweeter (or at least this is my feeling). Any other suggestion? I want to stay under 100EUR/driver. |
#2 |
diyAudio Chief Moderator
I have not used the MCA15RCY. But I have used CA22RNY and I can say that this is a very good family of drivers. Natural tone, very good resolution, excellent motors. Very easy to use, no enormous rugged breakup mounts towards the high end of their passband.
#3 |
What about dome midranges?
Tang Band 75-1558SE or Dayton RS52AN? Anybody used this? |
#4 |
I used the MCA15RCY in a 3-way from about 350-2.2k 4th order and it performed well. Well behaved, smooth response.
You didn't say how loud you want to play it, so I suggest S. Linkwitz "SPL max" spreadsheet. |
#5 | |
I don't what it to play too loud. I have a 75W amplifier and potentiometer is at 8-10 o'clock. What I want is very clear sound and large sweet spot. For test, I tried only with woofer and tweeter crossed very low (~1khz). I liked it very much. Of course, test was at low volume. I hope that a dome midrange will give me the same or better sound, but allow me to play at higher listening levels. Maybe also MCA12RC is a a good variant. |
#6 | |
I have the MCA12RCs in Troel Gravesons 3 way classic design and am very pleased with them. Very clear sound with exellent dispersion. http://www.troelsgravesen.dk/3WClassic.htm Try them, you`ll like them. Steve. |
#7 |
I will try both: Dayton RS52AN and Seas 12RC
#8 |
I have received RS52AN. I played some voices fullrange. It sounds very very good indeed.
What it bothers me is that dome seems made of plastic. Not Aluminium. |
#9 | |
It should be black anodised aluminium which unlike plastic will not survive touching it to find out. |
#10 | |
It is black, but it seems not anodized aluminium. I did not press very strong to see if it bends. I just touch it to see texture. It feels like plastic to me. Driver looks like here: http://www.speakerdesign.net/dayton_...yton_rs52.html I just want to know if it is made like this by dayton, or it is a counterfeit. Anybody else have this driver and can check? |
| Seas 27TDFC H1189 vs Seas 27TFFC H881 | ermes | Multi-Way | 4 | 19th April 2011 01:20 PM |
| MCA15RCY replacement | gbadaut | Multi-Way | 17 | 29th June 2009 06:29 PM |
| My SEAS MCA15RCY OB 3ways.... | JandG | Multi-Way | 3 | 2nd February 2008 07:34 PM |
| Wanted: Seas W17EX001, Usher 8945P, Seas CA18, or somewhat similar mid-woofer. | Spasticteapot | Swap Meet | 2 | 7th March 2007 04:06 PM |
| Seas Excel W26 compaired to Seas L26 (10") | harruharru | Subwoofers | 9 | 11th March 2005 09:47 PM |
| Page generated in 0.10828 seconds (79.68% PHP - 20.32% MySQL) with 10 queries |
