Old 30th May 2008, 02:51 PM   #1
Default speaker burn in using lg mini home theatre?
hi there, i have a diy 8 ohm speaker, i like to burn them but dun want it on my tube amp. can i burn them with LG mini home theatre?
http://www.lge.com/products/model/detail/fb162.jhtml
i just substitute the two speaker from lg with my new diy speaker. is it possible?
how to make sure that i wont damage my new speaker? thanks in advance.
Old 30th May 2008, 03:03 PM   #2
here is the spec for lg speaker:
Type 3 Way 3 Speaker
Impedance 4 Ω
Frequency Response 70 - 20,000 Hz
Sound Pressure Level 83 dB/W (1m)
Rated Input Power 80 W
Max. Input Power 160 W
Net Dimensions (W x H x D) 128 x 295 x 240 mm
Net Weight 4.1kg
lg amp spec:
Stereo mode 80 W + 80 W
Output Power 80 W + 80 W
T.H.D 0.5 %
Frequency Response 40 - 20000 Hz
Signal-to-noise ratio 75 dB
impedance is different, still possible? can damage the speaker or the lg?
Old 30th May 2008, 03:39 PM   #3
Hi, yes it is possibe, no you will not damage anything, /sreten.
Old 30th May 2008, 04:05 PM   #4
hi sreten, just to make sure that its different impedance. my diy speaker is 8 ohm while lg speaker is 4 ohm... perfectly ok?
Old 30th May 2008, 04:12 PM   #5
Hi, perfectly OK, the reverse may not be, /sreten.
Old 6th June 2008, 05:54 AM   #6
hi Sreten, thx alot. it works fine. great
New Home Theatre Sub dark_avenger Subwoofers 11 29th December 2007 02:28 AM
DIY Home Theatre luckybob Multi-Way 4 25th May 2006 06:19 AM
Home Theatre Speaker Drivers 4 DYI Bazooka_j0 Multi-Way 2 6th February 2005 02:54 PM
Home Theatre bhg41088 Multi-Way 4 16th August 2004 01:32 PM
Page generated in 0.09695 seconds (71.75% PHP - 28.25% MySQL) with 10 queries
