Old 27th May 2008, 10:37 PM   #1
Cool Starting Question
Hello everyone,
Im Ray, I'm a musician and a recording and mixing enthusiast. I have some backgrounds on acoustics since i've designed and buid myself the acoustic treatment for my home studio mastering room. I did all the reading for that purpose and of course i will do it for this new DIY proyect i have in mind if it worth te effort. Well, I'll like to start with a simple question.
Is it a good idea to build near field monitors (for mixing in a small room) from a pair of CAR speaker sets?
The speakers are 130KP from FOCAL and they sounded GREAT in my car.
130mm (5") Woofer
25mm (1") Voice coil
85mm (3.5") Magnet
TNK inverted dome tweeter
Separate crossover : 12/12dB/oct (3.5kHz)
Adjustable tweeter level : (0,-3,-6dB)
Max. power : 140W
Nom. power : 70W
Sensitivity (2,83V/1m) : 90dB
Frequency response : 70Hz – 20kHz
Any help?
Old 27th May 2008, 11:28 PM   #2
nigelwright7557's Avatar
Default Re: Starting Question
Originally posted by renderbass
Hello everyone,
130mm (5") Woofer
85mm (3.5") Magnet
Max. power : 140W
Nom. power : 70W
Any help?
The sensitivity is not very good.
I would be looking at 95db or more for a good speaker.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 28th May 2008, 12:42 AM   #3
Cloth Ears's Avatar
You may be able to, but I can't find much information on the mid-bass used in this 2-way package from Focal. In general, car audio drivers are designed more for robustness than actual fidelity, but there are exceptions.
Unless you can find out the box dimensions suggested for this particular speaker combination, the problem will be in designing a box to put it in that gives you the best results. For better results, you might want to try a true co-axial driver (rather than, as this Focal is, a mid-bass and a woofer presented as a package) like the PHL 1240TWX - if they're still available.
And sensitivity is an indication of how much power is required to achieve a sound pressure level. It is not (in itself) and indication of quality. Lower sensitivity = more power to reach the same sound level. Higher sensitivity = less power to reach the same sound level. There are trade-offs for both approaches.
Jont.
"It is impossible to build a fool proof system; because fools are so ingenious."
Old 28th May 2008, 12:49 AM   #4
Default Re: Re: Starting Question
Sensitivity is very important to loudness.
Bear in mind the ear is logarithmic and so needs 10 times more power to percieve a doubling in loudness.
Old 28th May 2008, 01:54 AM   #5
Cloth Ears's Avatar
Agreed. I just put that in for our initial poster, who indicated he liked the sound of the drivers in his car. Finding some speakers that you like is half the battle. And finding some that'll work co-axially (is that a word?) is probably an even better thing.
Jont.
Old 28th May 2008, 10:45 AM   #6
Car speakers will only work the way you intend wall or soffit mounted.
Boxes do things to the response and near and farfield are not the same.
$850 for the focal stuff ? - do me a favour .........
< half the price : http://www.madisound.com/catalog/pro...oducts_id=8307
~ the same ball park
http://www.madisound.com/catalog/pro...oducts_id=8362
http://www.zaphaudio.com/SR71.html
http://www.zaphaudio.com/ZRT.html
May need to fiddle for near field use. Depends on distance and if
a rear wall is involved (should not be, speakers are still freefield).
Or similar size to the Focal :
http://www.zaphaudio.com/ZD5.html
FWIW the 5" Focal driver specs are awful for a hi-fi speaker :
Fs = 89Hz, Vas = 5 litres and Qts = 0.7, good for in-car + sub.
/sreten.
Old 28th May 2008, 09:46 PM   #7
sdclc126's Avatar
Oh my gosh that Zaph ZRT looks amazing.
Soft Dome
Old 29th May 2008, 04:38 PM   #8
peter_m is offline peter_m  Canada
http://www.speedsound.com/product.as...ific=jnfmening
$500 to $800... ouch! save your money or make a donation to a non-profit org.
Zaph has a near field x-over design for his L18 2-way system. I last saw it here http://htguide.com/forum/showthread....ight=l18+field But his link doesn't work anymore. Maybe someone still has a diagram so ask around. Here is the original L18 design: http://zaphaudio.com/audio-speaker17.html
Peter
Old 1st June 2008, 08:31 AM   #9
Default Thanks!
Wow!
Thank you all for your input. I'll try to sell those car sets then... and start saving money to BUY some dedicated monitors of a decent reputation instead of trying to get water out of the rocks...
Ray
Just starting GrooveCat Introductions 4 11th January 2008 02:37 PM
Just Starting out Freestyling Introductions 6 9th November 2007 08:38 AM
Question before starting with MC preamp Jean-Paul_2 Solid State 1 20th May 2007 02:18 AM
starting over trailsnail85 Car Audio 6 12th December 2005 05:20 AM
starting over again... help! fazman Subwoofers 6 25th May 2005 08:26 PM
Page generated in 0.12750 seconds (77.74% PHP - 22.26% MySQL) with 10 queries
