What are the functions of the two sides in an open baffle design utilizing an, let's say, A-N's super 12? Do they just provide an angled support for the main board or do they also help to increase the bass? I am thinking about, in order to maximize the front board size and to minimize cost, simply using two 4x8 mdf boards for the drivers and lean them against a wall. Thanks!
#2 |
#3 |
That does sound simple! How long is the wall you will be leaning them up against? Maybe you can fabricate a top behind the 4x8 with some rubber of some kind to reduce vibration against the wall where it touches. Also, maybe consider bracing on the back so the boards dont bend over time from the weight of the driver. Godzilla |
#4 |
Very interesting ideas. I need to do more studies!
#5 |
Do you have the opportunity to place the baffles this way?
#6 |
mudihan, the whole point of open baffle is to cancel the sound emanating to the sides in order to minimize early reflections
to do what you suggest is almost the same as putting speaker in the box |
| Does open baffle suffer from baffle step? | 454Casull | Multi-Way | 15 | 19th May 2012 03:12 PM |
| Open-baffle baffle length | matejS | Multi-Way | 2 | 21st September 2010 04:49 PM |
| Murphy baffle radios [ open baffle ] | keithpeter | Full Range | 10 | 11th September 2007 07:59 PM |
| what effect does baffle have on open-baffle system? | kappa546 | Multi-Way | 6 | 24th January 2006 10:21 PM |
| Australians- what solid timbers for baffle? (open baffle loudspeaker) | tktran | Multi-Way | 13 | 29th November 2004 11:09 PM |
| Page generated in 0.08894 seconds (69.47% PHP - 30.53% MySQL) with 11 queries |
