Ultimate Open Baffle Gallery - Page 96 - diyAudio
Old 21st June 2013, 03:58 AM   #951
gainphile's Avatar
Pics and specs please... it's a gallery thread
http://gainphile.blogspot.com
Old 21st June 2013, 08:53 AM   #952
6.283 is offline 6.283  Germany
OK, but one last answer to DrDyna, maybe he should open a dedicated thread.
The symmetry that buys you vertical control with normal speakers is not really required with dipoles. There you already have a somewhat narrower dispersion. If you now go with mtm you could run into vertical response issues at shorter wavelengths. Also, the two m's could outrun the neo3 and so you will have to decrease the output and the spl advantage is gone with more cabling and amps and less mechanical stability.
With a LX521 or NaO Note type speaker there is no "listening down" issue.
If you really want to go wmtmw then it is better to go 8-4-t-4-8" in a simple baffle (maybe hourglass shaped) instead of the H-frame. But the neo will most likely be again the bottleneck. If not in SPL then in size (too narrow vertical response resulting in sharp interference nulls at cross over F).
2Pi-online.de
Old 21st June 2013, 09:10 AM   #953
StigErik's Avatar
I have tried both WMTM and WMMT configurations, and found that that latter measured and sounded better.
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
Old 21st June 2013, 01:48 PM   #954
DrDyna is offline DrDyna  United States
DrDyna's Avatar
Thanks 2Pi. The beauty of active open baffle I guess is how simple (read: easy to make new ones) the baffle can be, so I might go through quite a few iterations before I'm happy. I understand what you guys are saying about the design that's similar to James Trexx's Gate and I could run into issues, but I'd like to at least try it and measure it to see what I get. If the Neo3 ends up running out of gas or has dispersion issues, it would be fairly trivial to swap, or perhaps even add another one?
Gainphile, sorry about mudding up the thread with all this silly talking! If it's any consolation, your 8 channel Class D build is what really inspired me to think I could afford to go fully active and build a massive open baffle in the first place
Ok, I'll stop, my next posts in here will be pictures and measurements of whatever I end up building. Cheers fellas, and thanks for the info
Old 22nd June 2013, 03:40 PM   #955
Alpha 15A from Eminence, this time with Sonido SFR200
Old 22nd June 2013, 04:45 PM   #956
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
DrDyna, I am using MTM with my AINO 4-way dipoles. High-Ms are xo'd now 550-3100 and when playing sine above 2kHz I can hear comb filtering, but it is not noticable with music. My T is Fountek NeoCD3.5H which is also very narrow vertically. But, I've been thinking about to set it to WMT just for testing how it sounds. It is easy with minidsp.
AINOgradient speaker project
Old 24th June 2013, 12:13 AM   #957
Here are a few pics of my most recent OB speakers incarnation:
Design goal was to make them fit as well as possible into a normal domestic living room (i.e. spouse had to approve finished look). And to be able to live without additional acoustic room treatments. Angling in design makes them workable close to the front wall.
Click the image to open in full size.Click the image to open in full size.
W-baffle with 2x Acoustic Elegance DP10s, Seas W22 paper excel mid and SS illuminator tweeters. Each woofer driven by 200W, with active crossover to mid/top and another 200W amplification. Passive filtering between mid and tweeters.
More details, reflections and some measurements in the separate thread - My open baffle project on ortho acoustic design ideas.
/Mats
Old 24th June 2013, 04:21 PM   #958
Juhazi's Avatar
The link to my AINOgradient project doesn,t work. A new try here Aino gradient - a collaborative speaker project
Directivity measured from 1,5m distance, 9ms IR window
Old 24th June 2013, 05:28 PM   #959
Nicely done sir......
Old 25th June 2013, 01:16 AM   #960
Fantastic way to cover the speakers Mats. You Swedes are so good at that! Nice job.
Greg
Open baffle or no baffle for nearfield full range monitors? mdevelde Full Range 19 18th November 2016 05:26 PM
Ultimate Open baffle for tannoy red 15 inch murphythecat8 Full Range 20 30th January 2013 01:29 AM
Upwards aligned open baffle? ( pop box meets open baffle ) OllBoll Full Range 3 28th March 2011 02:00 AM
Copyright ©1999-2017 diyAudio
