Ultimate Open Baffle Gallery - Page 90 - diyAudio
Old 15th November 2012, 06:56 AM   #891
Originally Posted by schlager View Post
Here is my new OB project, inspired by StigErik.
Slot Loaded OB with 4x 15" sub from 20-400 hz, 6x 8" Goldwood from 400-1000 hz and 6x NEO8s from 1000 and up. X-over 48 db. Fun project that actully works pretty well, if you aply some digi EQ.
Regards Sebastian
Nice work Sebastian, StigErik has a lot to answer for
My speakers don't look anything I imagined they would thanks to his influence. His are definitely a benchmark for OB.
Did you try crossing them over lower say somewhere around 150Hz?
Old 15th November 2012, 02:45 PM   #892
Originally Posted by SpinMonster View Post
I guess its really a tech question and not to find an alternative way around it.
What does it take to get a 7 or 8 incher to get to 80hz? IE what baffle size? How much EQ?
How loud do you want them to get?
Insert witty signature line here.
Old 15th November 2012, 06:20 PM   #893
95db.
I'm trying to understand the science behind baffle size and low frequency.
In othr words can you plaese tell how the baffle relates to low frequency.
Old 15th November 2012, 08:38 PM   #894
seanny is offline seanny  United States
http://www.linkwitzlab.com/spl_max1.xls
Old 21st November 2012, 04:20 AM   #895
Legis is offline Legis  Finland
Legis's Avatar
The lastest project, 10x8" midbass line arrays in L-baffle:
Old 21st November 2012, 06:03 AM   #896
do you have a picture of the back of the L-baffle?
Old 21st November 2012, 06:10 AM   #897
Legis's Avatar
Here, the front baffle is 36cm wide and the side 15cm deep.
Old 21st November 2012, 06:26 AM   #898
ScottG is offline ScottG  United States
There's just something comforting about the look of a big-@ss 'stat.
perspective is everything
Old 21st November 2012, 08:39 AM   #899
First that stain color is amazing.
What frequency do you reach down to with those 8's without eq?
Old 21st November 2012, 09:43 AM   #900
Legis's Avatar
Here are the sensitivity and linearity measurements done at 2,83V from the listening spot, ~2,5m away from the speakers. Both are done completely without eq, including no 6dB/oct dipole compensation, there is just LR4 low pass at 800Hz.
Right
Left
Open baffle or no baffle for nearfield full range monitors? mdevelde Full Range 19 18th November 2016 05:26 PM
Ultimate Open baffle for tannoy red 15 inch murphythecat8 Full Range 20 30th January 2013 01:29 AM
Upwards aligned open baffle? ( pop box meets open baffle ) OllBoll Full Range 3 28th March 2011 02:00 AM
Copyright 1999-2017 diyAudio
