Ultimate Open Baffle Gallery - Page 72 - diyAudio
Old 24th October 2011, 09:31 PM   #711
Originally Posted by Godzilla View Post
That probably sounds great. Are you powering with woofers with a dedicated amp? That's what i would do. I love it!
Hi God,
He says he is new to active crossovers so we have to assume he is.
Old 25th October 2011, 06:44 AM   #712
The room is small. I have to compromize.
My amplifiers are:
Pass Labs XP10 preamp ->
DBX x-over ->
Tweeter: First Watt F4
Fullrange (mid): another F4
Woofers: Rotel 2x100 watt class-D
Old 25th October 2011, 02:52 PM   #713
Godzilla's Avatar
Ooooohhh, i bet that sounds goooood! Nothing's perfect but your setup should produce some great sound. I wonder how the slimming baffle top changes the sound compared to a wider one? I also wonder how much better the bass is by doubling up the Alphas... I bet two make even more of an impact than one. If i had the room i'd stack two H-frames. So many great options out there now that we have software to sim before building. I can't stop thinking about my OBs... love the sounds they make.
I'd rather have your setup than just about any commercial product out there regardless of price.
Old 28th October 2011, 08:43 AM   #714
gainphile's Avatar
Beautiful NaO Note being built.
http://gainphile.blogspot.com
Old 28th October 2011, 05:10 PM   #715
Slimmed tops give probably better perspective and less baffle step peak. Now i cross at 300hz with 24dB Linkw.R.
Two Alpha sounds 40-50% better than one. More precise, a little bit deeper and they can handle more power.
Double H-frames has been on my mind for a while. I have the new Fostex Fe203en-s ltd edition and daydreams about alternative consepts.
They sounds like Tom Petty: In To The "GREAT WIDE OPEN" (i am playing it right now)
I am struggling with a little to dull freq. curve. But thats the game with active xovers isnt it?
Old 28th October 2011, 05:31 PM   #716
Godzilla's Avatar
I'm curious how the Fostex 203 will compare to the TB 1808 on OB with the Alpha's... You've got a nice setup.
300hz xover seems high. How did things sound closer to 200hz?
Old 28th October 2011, 07:35 PM   #717
Toaster is offline Toaster  United Kingdom
Nice NaOs, although the panels seem to be attached to some big H-frames rather than the NaO U-frame. Are you building these gainphile? I really should buy a set of ER18s and get mine done.
Old 29th October 2011, 01:06 PM   #718
gainphile's Avatar
No, they are not mine. I wish
Btw. the kit price at Meniscus is $1k -something. Is that right? Even the 4 woofers themselves would cost about that much!
Old 29th October 2011, 02:07 PM   #719
gainphile's Avatar
The birth of Orion4 ??? ... 2004!
DIY Chicago 2004
Old 29th October 2011, 03:26 PM   #720
john k...'s Avatar
Loud and proud:
2 Peerless SLS 12" + 2 Peerless SPS 10" per side, SS 8545 mids, SB Aciustic 1" dome.
MiniDSP 2x8 24/96 active dsp crossover.
John k.... Music and Design NaO dsp Dipole Loudspeakers.
Open baffle or no baffle for nearfield full range monitors? mdevelde Full Range 19 18th November 2016 04:26 PM
Ultimate Open baffle for tannoy red 15 inch murphythecat8 Full Range 20 30th January 2013 12:29 AM
Upwards aligned open baffle? ( pop box meets open baffle ) OllBoll Full Range 3 28th March 2011 01:00 AM
Copyright 1999-2017 diyAudio
