Ultimate Open Baffle Gallery - Page 44 - diyAudio
Old 5th December 2010, 03:35 AM   #431
craigj is offline craigj  United States
Gainphile,
When you are done playing with your new wavegides, You might want to grab a 3" driver + Neo3 pdrw instead and make this: ; >)
Click the image to open in full size. Click the image to open in full size.
Thank you JohnK, I really think you are on to something that is very nice (and not pink).
Cj
Old 5th December 2010, 11:30 PM   #432
gainphile's Avatar
CJ, that looks like an excellent candidate for Orion 5 !
Or NaO 2 ?
What is your listening impression and do you have plots?
This is my work in progress ... code name S16WG
It is controlled-directivity from 20hz to 20khz. I've measured the WG part and will need to go outdoor to measure the whole speakers.
http://gainphile.blogspot.com
Old 6th December 2010, 11:20 AM   #433
keyser is offline keyser  Netherlands
keyser's Avatar
Originally Posted by skorpion View Post
keyser,
I could not get consistent results replaying CD records with no baffle. Most sounded thin in high bass, low midrange compared to the sound with this small 8" baffle. Also without baffle I needed 15 dB shelving EQ for the 6ND430 and 300 Hz crossover frequency. Now with the 20 cm baffle there is no need for EQ at all. No doubt for this combo baffle is better than no baffle soundwise.
But also no doubt you win both clarity and definition by separating bass baffle from the midrange and tweeter. This is easily heard.
/Erling
In my system I simply apply sufficient EQ to make it sound full-bodied (a 14 dB low Q notch at the first dipole peak). Alright, it eats quite a bit of dynamic range, but the radiation pattern is much improved and it sounds better too.
Dutch & Dutch
Old 6th December 2010, 07:41 PM   #434
I have posted some more info and measurements on the 'Blindstone' over at AC: The BlindStone OB .
/Erling
Old 7th December 2010, 05:24 AM   #435
navin is offline navin  India
navin's Avatar
Send a message via MSN to navin Send a message via Yahoo to navin
What on earth is the woofer used in the picture on the right?
...still looking for the holy grail.
Old 7th December 2010, 09:19 AM   #436
keyser's Avatar
It pretty much looks like an Aurasound.
Dutch & Dutch
Old 7th December 2010, 10:36 AM   #437
navin's Avatar
The conical structure facing upwards is the magnet of a 12" Aurasound woofer? something like this
https://www.madisound.com/store/prod...products_id=80 ?
Old 7th December 2010, 03:05 PM   #438
Close, but the woofer is the NS12-13-4A that was was on clearance for $92 at Madisound recently;
Good price, and works pretty well for this W application.
Old 7th December 2010, 05:28 PM   #439
But soundwise I think that the Alpha15s are the weakest link in this setup. You can occasionally hear, I think at least, notes that could be more stringently reproduced.
/Erling
That is the reason why I was suggesting to XO lower.
Old 7th December 2010, 10:04 PM   #440
steffda is offline steffda  Germany
Default Spheres
Just got them ready. The loudspeaker is a AX830E from Hifonics, the diameter is about 50cm. It's an ventilated box.
The leather-work is not that perfect, but for the first time it's fine
Open baffle or no baffle for nearfield full range monitors? mdevelde Full Range 19 18th November 2016 05:26 PM
Ultimate Open baffle for tannoy red 15 inch murphythecat8 Full Range 20 30th January 2013 01:29 AM
Upwards aligned open baffle? ( pop box meets open baffle ) OllBoll Full Range 3 28th March 2011 02:00 AM
Copyright 1999-2017 diyAudio
