Ultimate Open Baffle Gallery - Page 231 - diyAudio
Old 29th May 2017, 03:20 AM   #2301
ashok's Avatar
Originally Posted by kec View Post
I like the Alpha 8A. Pretty smooth.
I feel the mid band of the Alpha6A is better than the Alpha8A but overall the Alpha 8A sounds better because of the extended LF it has.
Like the Eminence CX10 and the CX12. The 10 sounds better in the mids than the 12 but the 12 has audibly better LF and so sounds 'fuller' . But I guess you can eq all drivers to sound similar. Wonder if the mids would sound different then ?
AM
Old 29th May 2017, 05:45 AM   #2302
DieterK is online now DieterK  Germany
DieterK's Avatar
I Think the problem are the THD of the Chassis. A smaller Mid-Driver for Open-Baffle must have more Xmax. The Xmax of the Alpha6a is small for a 6-incher in Open-Baffle. So you will drive it in higher THD than a equal 8-incher as same dB. The bigger the cone the less can Xmax be. Some people like more k2 as to see in Tube-Amps. But is it what we want?
Sorry for my english, I hope you understand....
Best Regards
Dieter
Old 17th June 2017, 01:17 PM   #2303
manninen's Avatar
https://www.youtube.com/watch?v=WizvSy3y9gw
Open baffle or no baffle for nearfield full range monitors? mdevelde Full Range 19 18th November 2016 04:26 PM
Ultimate Open baffle for tannoy red 15 inch murphythecat8 Full Range 20 30th January 2013 12:29 AM
Upwards aligned open baffle? ( pop box meets open baffle ) OllBoll Full Range 3 28th March 2011 01:00 AM
Copyright 1999-2017 diyAudio
