Ultimate Open Baffle Gallery - Page 230 - diyAudio
Old 11th April 2017, 11:23 AM   #2291
kec is offline kec  United States
kec's Avatar
Originally Posted by 6thplanet View Post
Looks more like a JBL CD tweeter, kec...
Well, Selenium/JBL
MSI E350IS mITX > Foobar > SPDIF > miniDSP 4X10 > Crown XLS1000 > ?
Old 11th April 2017, 04:40 PM   #2292
6thplanet's Avatar
Nice
Old 6th May 2017, 12:35 PM   #2293
A new toy has arrived.
Electro Voice TRX 15, good as new.
Hope to have a OB ready this weekend.
Old 6th May 2017, 01:07 PM   #2294
ashok's Avatar
Originally Posted by kec View Post
I like the Alpha 8A. Pretty smooth.
I like the Alpha8A too. Always wanted to make a two way with their horn tweeter on an OB. The bare Alpha8A sounds nice but the Alpha 6A is better but looses out due to lack of low end on an OB.Eq is possible but not sure how that would sound besides restricting it's power capability. However both are very efficient and this may not matter much in actual use.
Too many projects and too little time !
AM
Old 8th May 2017, 03:20 PM   #2295
Originally Posted by Bergfinn View Post
Well, not nice.
But interesting, yes.
I am a newbie in DIY, and I want to eksperiment with more home made coax.
Need some better tweeters, and I want AE Dipole 15" to play with. Have to grow some money then. [/IMG]
What digital crossover do you use?
Old 9th May 2017, 11:18 AM   #2296
I am using Audiolense XO (on a windows pc) and a 8 channel RME Fireface USB soundcard.
Very easy to get good sound with this setup. Just playing around with different drivers in and out. FIR filters with automatic time alignment.
Old 14th May 2017, 09:27 AM   #2297
Hi everyone, I built these based on lampizator p17 OBs. xover is lampizators. Being in New Zealand Saba greencones and altecs are expensive so I sourced out Plessy 5x7 midbass, Philips paper tweeter and philips 12 inch woofers. the baffles are covered in polar fleece to eliminate diffraction. they are very good imo. the orange amp is my tda2030a chip amp btw.
Hi folks, I am building an open baffle project inspired by Lampizator P17 also. My question is, how does the polar fleece on the baffle help with the sound? Is it noticeably better than bare wood/MDF? Thanks!
Jonathan
Old 14th May 2017, 06:57 PM   #2298
MITsound's Avatar
I always thought diffraction was frequency irregularities brought on by sharp edges redirecting higher frequencies , either fr om the baffle edges, or the plates or frames of non flush mounted drivers.
I suppose the polar fleece would dampen or eliminate those shorter wave treble problems.
It would help eliminate baffle reflections as well, so that would assist with imaging .
The downside , if you like the look of it, is cats may thank you for the big noisy scratching posts .
On the other hand, my point is still moot.
Old 15th May 2017, 04:57 AM   #2299
Hi MITsound,
Thank you for the explanation. That sounds like a nice addition to the project, although I very much prefer the looks of bare wood, even if it's just plain MDF. Maybe it's worth it for the advantage it brings to the sound.
Jonathan
Old 28th May 2017, 10:31 PM   #2300
MITsound's Avatar
Hi MITsound,
I find it's better to try these things , for yourself. I've been told point blank, a few of my ideas wouldn't work well, and empirically, they worked very well.
Sims are an excellent starting point, but fine adjustments to suit one's personal tastes, ought to be tweaked by ear. Otherwise, we'd all look at graphs on powered pro monitors, and buy those.
Open baffle or no baffle for nearfield full range monitors? mdevelde Full Range 19 18th November 2016 04:26 PM
Ultimate Open baffle for tannoy red 15 inch murphythecat8 Full Range 20 30th January 2013 12:29 AM
Upwards aligned open baffle? ( pop box meets open baffle ) OllBoll Full Range 3 28th March 2011 01:00 AM
Copyright 1999-2017 diyAudio
