Ultimate OB Gallery - Page 91 - diyAudio
Old 21st November 2012, 11:35 AM   #901
Originally Posted by Legis View Post
Here are the sensitivity and linearity measurements done at 2,83V from the listening spot, ~2,5m away from the speakers. Both are done completely without eq, including no 6dB/oct dipole compensation, there is just LR4 low pass at 800Hz.
Im impressed with the output and efficiency. A row of 8's or 10's with an RD 50 may be the way I go.
What 8" driver is that? What are the specs (Fs, Qts, Vas)?
Thanks for sharing the results.
Old 21st November 2012, 02:50 PM   #902
Legis is offline Legis  Finland
Legis's Avatar
Yep they are very voltage efficient, I have wired arrays to 3.2 ohm nominal impedance. The driver is Gradient Axis AXT-08, basically paper/kevlar cone version of the Dayton Audio RS-series with a slightly smaller xmax(I think it's smaller). Driver has been tested in 2011/3 Klang & Ton. Basically an accurate and punchy woofer with high sensitivity, low moving mass, strong motor and high Qms. Efficiency is about 92dB/w, qts 0.3, Mms 21 grams, Vas 50l, Le 0,4mH, voice coil diameter 39mm, xmax around +/- 4mm (+/- 5,5mm mathematical/realistic).
Old 23rd November 2012, 01:26 PM   #903
That's a pretty sexy looking array. Well done!
Is that veneer a Pelin Burl?
Bob
Old 23rd November 2012, 01:52 PM   #904
Legis's Avatar
Bob
No veneer, it's local birch plywood (2x24mm all the way), stained with water based dark mahogany and mildly french polished with amber shellac.
Old 23rd November 2012, 03:13 PM   #905
Wow, that's some very nice plywood! You're lucky to have such a material.
Old 26th November 2012, 02:43 PM   #906
sraudio is offline sraudio  Lithuania
sraudio's Avatar
Here are mine latest open baffles. Driven by current drive amplifier.
Old 26th November 2012, 03:48 PM   #907
puppet is offline puppet  United States
Nice sraudio. How would you define the sound character?
Old 26th November 2012, 06:39 PM   #908
sraudio's Avatar
As engineer I think it is not very wise trying to describe the sound character, but in a few words it is very dynamic and natural.
Old 27th November 2012, 12:57 PM   #909
Here's some of my OB's projects, Electrovoice SP12B and SP15 and PHY-HP.
Enjoy!
Old 27th November 2012, 01:15 PM   #910
kendt is offline kendt  Canada
Default My OB w.i.p.
Here is my latest. Not finished obviously but sounding very very nice. The tweeter is currently on the rear (wanted to audition for a while before cutting holes) The phase plugs shown are only temp. Waiting on the return of more favourable weather to finish.
Bose Wave Music Syst. Ultimate Sound? Gallery from inside Devices - Serv. Man. wanted tiefbassuebertr Solid State 51 28th November 2013 01:27 PM
S11 OB - Revisiting Desktop OB design using Seas 8" and Tang Band Full-Range gainphile Multi-Way 27 23rd January 2013 09:51 PM
Ultimate cheapskate OB midrange?? Moondog55 Multi-Way 4 30th November 2011 05:09 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright ©1999-2015 diyAudio
