Ultimate OB Gallery - Page 89 - diyAudio
Old 19th October 2012, 04:47 PM   #881
john k...'s Avatar
Originally Posted by Toaster View Post
What's the tweeter John?
Currently it is undecided. Shown with Vifa OX20SC00-4 3/4" dome. I may add one to the back as well.
John k.... Music and Design NaO dsp Dipole Loudspeakers.
Old 19th October 2012, 06:31 PM   #882
matevana's Avatar
Is that a 27TFFNC/G on the new SL design? I doubt it, but if it is, it's significantly less expensive than the Orion's tweeter. Also, it's hard to make out in the photo, but what is that below the (I'm guessing) 10" mid bass driver? Also appears to have no magnet mount on any of the open panel drivers. The only drivers I recognize for sure are the Seas L26's in the modified W baffle.
Old 23rd October 2012, 11:04 AM   #883
Here is my new OB project, inspired by StigErik.
Slot Loaded OB with 4x 15" sub from 20-400 hz, 6x 8" Goldwood from 400-1000 hz and 6x NEO8s from 1000 and up. X-over 48 db. Fun project that actully works pretty well, if you aply some digi EQ.
Regards Sebastian
Old 23rd October 2012, 01:01 PM   #884
Vix is offline Vix  Yugoslavia
Vix's Avatar
Old 23rd October 2012, 02:19 PM   #885
Elias is offline Elias  Finland
Elias's Avatar
Originally Posted by john k... View Post
The baffle is similar to the note but the speaker will look like the NaO II RS with grills on. Sorry, I'm old school. I like speakers with grills. I don't like looking at the drivers.
It wonders me though, using grills and still miss the opportunity to use PA drivers which mainly are not designed for looks but for other interesting technical properties. Why did you choose to use 'hifi' drivers if you are going to cover them up unvisible ? As in 'hifi' drivers considerable design effort has been put to outlook.
Liberate yourself from the illusion of two speaker stereo triangle
Dipole Bass vs Monopole Bass Stereophonic Sound from a Single Loudspeaker 3 Speaker Linear Stereo Matrix Wavelets
Old 13th November 2012, 05:53 AM   #886
gainphile's Avatar
An awesome pic
http://gainphile.blogspot.com
Old 13th November 2012, 07:18 AM   #887
Jonasz is offline Jonasz  Sweden
Jonasz's Avatar
SL is a big guy, those aren't small speakers...
Old 14th November 2012, 10:44 AM   #888
Is it possible for a 2 way OB to have extension to 80hz with 7 or 8" midbass drivers?
Maybe 2- 7" with one of the two sealed and crossed passively with a single inductor so it can be run with two amp channels actively?
Or option two, with a wide/tall baffle to extend the range of a 7" or 8" driver?
Old 14th November 2012, 05:31 PM   #889
Toaster is offline Toaster  United Kingdom
Yes, but it depends how loud you want it to go! If baffle width isn't an option a larger drive unit could be used to advantage of course- there are lots of decent cheap ones.
Old 15th November 2012, 04:29 AM   #890
I guess its really a tech question and not to find an alternative way around it.
What does it take to get a 7 or 8 incher to get to 80hz? IE what baffle size? How much EQ?
Ultimate cheapskate OB midrange?? Moondog55 Multi-Way 5 8th November 2015 09:02 PM
Bose Wave Music Syst. Ultimate Sound? Gallery from inside Devices - Serv. Man. wanted tiefbassuebertr Solid State 51 28th November 2013 02:27 PM
S11 OB - Revisiting Desktop OB design using Seas 8" and Tang Band Full-Range gainphile Multi-Way 27 23rd January 2013 10:51 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright ©1999-2016 diyAudio
