Old 5th December 2011, 02:53 PM   #761
Originally Posted by Helmuth View Post
Due the wave length and path traveled the reflection will ad in opposite phase
...only for certain frequencies. The very same is true for a dipole. Now consider that we're talking about wavelengths that don't produce "reflections" because the room is small compared to the wavelength.
Markus
Old 5th December 2011, 04:04 PM   #762
Helmuth is offline Helmuth  Netherlands
Helmuth's Avatar
Witch wave length are you thinking of?
( (( KUGELWELLE )) )
recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet
Old 5th December 2011, 04:09 PM   #763
All frequencies below and around the Schröder frequency.
Markus
Old 5th December 2011, 04:59 PM   #764
Helmuth's Avatar
that would be below 200-300Hz with what I measure and hear it doesn't make sense what you say there.
So your making a faulty assumption somehow and I do not know why.
It also would mean the OB doesn't make sound below the schroder frequency.
Old 5th December 2011, 06:07 PM   #765
Why would an open baffle not make any sound below the Schröder frequency? Either your or my understanding of sound propagation in air is false.
Markus
Old 5th December 2011, 06:31 PM   #766
gainphile's Avatar
Markus do you have pics to share? This is a gallery thread
http://gainphile.blogspot.com
Old 5th December 2011, 07:11 PM   #767
gainphile's Avatar
Nice recently built Nao Note:
NaO Note preview
Old 5th December 2011, 09:29 PM   #768
Great build...ROUGH room for sure. Ouch!
Old 5th December 2011, 11:46 PM   #769
john k...'s Avatar
Originally Posted by rob g View Post
I do not know what he is talking about. Usually people worry about the out of phase wave from dipole not monopole. Even that is not a major concern in real rooms:
From Linkwitz lab's:
"Often concern is expressed over the fact that the rear radiation from a dipole is out of phase with the front radiation, and that thus any sound reflected from a wall behind the speaker would cancel sound coming from the front of the speaker. Cancellation can only occur when direct and reflected sounds are exactly of opposite phase (180 degrees) and of the same strength. Since direct and reflected sounds travel paths of different length, they undergo different amounts of phase shift. Thus, the phase and magnitude conditions for cancellation are given only at certain frequencies, if at all. At some other frequencies direct and reflected sounds will add. The same also applies to a monopole speaker in front of a wall. The only difference is in the frequencies for which addition and subtraction occur. The best remedy is to move the speaker away from the wall, or to make the wall as sound absorptive or diffusive as possible"
SL is talking in generalities here, as he often does, and about higher frequencies. The behavior of monopole, dipole and cardioids, due to the reflection from the wall behind the speaker is discussed HERE. And the real situation is more complicated due to room modes.
John k.... Music and Design NaO Dipole Loudspeakers. "We have no right to assume that any physical laws exist, or if they have existed up to now, that will continue to exist in a similar manner in the future." Max Planck
Old 6th December 2011, 05:23 AM   #770
lenta is offline lenta  Norway
I agree, room is untreated, and with worst floor material possible. I imagine how uncomfortable acoustics is. Dips an peaks in this room definetly can reach +-10db not onnly in bass.
diy sub gallery paulspencer Subwoofers 9 21st August 2005 12:01 AM
Amp Gallery Scribble Pass Labs 7 24th October 2003 04:46 PM
Copyright ©1999-2013 diyAudio
