Ultimate OB Gallery - Page 19 - diyAudio
Home Forums Rules Articles diyAudio Store Gallery Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Old 8th August 2009, 09:25 AM   #181
gainphile's Avatar
http://www.htguide.com/forum/printthread.php4?t=33492
http://gainphile.blogspot.com
Old 8th August 2009, 09:29 AM   #182
gainphile's Avatar
HT setup with 24 dipole woofers!
http://www.mfk-projects.com/theatre_woofer.htm
Old 8th August 2009, 11:11 AM   #183
chris661's Avatar
Default FRS 8 (promise I'll stop soon)
Cheaper here
http://cpc.farnell.com/visaton/frs-8...ohm/dp/LS01667
Like I said before - using the speaker alignment I used (OB+BR, where BR cancels OB rearwave), I can get to 60Hz, which is (annoyingly) lower than it would manage in a ported box. the downside, however, is the lack of volume available, which could only be fixed if more air was to be moved. So, here's an idea to play with: get 8 of them, put 2 of them in each baffle, across then the cancelling speakers behind, include the standard XO, and you'll get more air shifted, thus more volume!
I would post a pic, but I'm halfway through painting them - decided on minimalist white.
All in all - a good buy.
Chris
"If you underspecify some resistors they can add extra phlogiston to the music mix. This gives a much more dramatic effect than refulgence, however superb it may be. Phlogiston can move a listener in a way that ordinary music cannot." - DF96
Old 8th August 2009, 11:46 AM   #184
kipman725's Avatar
Send a message via MSN to kipman725
http://onecall.farnell.com/visaton/f...ohm/dp/LS01667
even cheaper but needs a university discount code
I stand corrected on the double bass (which as a bass player I rearly should know!)
wouldn't using 4 of them result in a larger enclosure?
Old 8th August 2009, 07:32 PM   #185
In theory either that or four enclosures of the original size. In practice hard to tell, because the Thiele/Small parameters are not in a range of any usual BR tuning, so you will end up with something too out of the ordinary to make rule-of thumb predictions.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 9th August 2009, 03:41 AM   #186
xecluded's Avatar
http://blog.ultimateavmag.com/ultima...ne_plus_ultra/
Old 13th August 2009, 01:54 AM   #187
gainphile's Avatar
Lowther OB setup:
http://www.audiocircle.com/index.php...7954#msg657954
Old 21st August 2009, 04:35 AM   #188
gainphile's Avatar
Thank you for the site upgrade. It looks and feels terrific !!
The designer called this "Antipodal Dipole"
http://home.swbell.net/taama/john/john.html
Old 21st August 2009, 04:44 AM   #189
gainphile's Avatar
"Lambda SEAS TMWW"
http://speakers.sub-optimal.net/index.php
Old 21st August 2009, 04:46 AM   #190
CLS is offline CLS  Taiwan
Wow! you dig this out! It's been quite a while. (I mean post #189)
I remember this guy had tried many configurations including several types of W-baffles and even with horn mid-high... etc. Astonishing ethusiasm!
Last edited by CLS; 21st August 2009 at 04:48 AM. Reason: Add description for the lag...
Ultimate cheapskate OB midrange?? Moondog55 Multi-Way 5 8th November 2015 09:02 PM
Bose Wave Music Syst. Ultimate Sound? Gallery from inside Devices - Serv. Man. wanted tiefbassuebertr Solid State 51 28th November 2013 02:27 PM
S11 OB - Revisiting Desktop OB design using Seas 8" and Tang Band Full-Range gainphile Multi-Way 27 23rd January 2013 10:51 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright ©1999-2016 diyAudio
