Hi @Stanislav,
thank you for the reply. The cross-over is actually at about 500 Hz. But, I saw open baffle (if the term is still applicable), that have exactly this combination, in fact I discussed this with @Pano.
Hi @Daihedz,
thank you for the information. As I researched it, this was one suggestion, the other one was to drill a small hole in the dust cup and use a small pick. I was also wondering, since the driver is vented, whether I could use a positive pressure through the vent.
Hi @Juhazi,
thank you for the reply. Actually, since I listen mostly to classical, I used that for the initial listening (Tchaikovskij, Bach, Morricone). And, yes, the feeling of space is what I was trying to describe so in-artfully.
Hi @SBA_SLOB_GUY,
Thank you, I can try that. I also have a Heil ATM with a front horn, so it is opened to the rear, so I can try that.
Hi @MITsound,
thank you for the reply. It is not that I do not like it, it is just that it is different form what I heard before. The best, although ridiculous description would be comparing it to the early color movies, wherein the colors were (for me unnaturally) vivid.
I have constructed the baffle to easily add extension, so I will play with that plus different cross-over point, equalization, etc.
Kindest regards,
M
Hi @Daihedz,
Hi @Juhazi,
Hi @SBA_SLOB_GUY,
Hi @MITsound,
Kindest regards,
M
@mefistofelez I appreciate the use of various screws, nuts and bolts to secure your woofers. I employ the same technique to take advantage of the different resonant frequencies of the various fasteners; This is often over looked, well done!
Hi @mordikai,
Kindest regards,
M
ROTFLMAO, this is completely unintentional; I ran out of the socket head screws of the correct length..I appreciate the use of various screws, nuts and bolts to secure your woofers. I employ the same technique to take advantage of the different resonant frequencies of the various fasteners; This is often over looked, well done!
Kindest regards,
M
I didn't expect it to work (and it didn't, through several attempts over the years), but the reason I went to open baffles was finding things lacking and things added from conventional cabinet or transmission line speakers.It is not that I do not like it, it is just that it is different form what I heard before. The best, although ridiculous description would be comparing it to the early color movies, wherein the colors were (for me unnaturally) vivid.
Kindest regards,
M
I think I fully agree with you it sounds different; in my case it's finally what I was after. So far. I've had many speakers I thought were "it" speakers for me in the past.
Hopefully I won't be getting the urge for making more sawdust any time soon.
Or at least cleaning it up.
I have same driver, and have been thinking to try open back. Will the lower range change much? I need to cross at 1100 hz. I just got the drivers, so I have not tried them out yet.Yes thats righte
- Ultimate Open Baffle Gallery
