Ultimate Open Baffle Gallery
Old 16th May 2018, 12:47 PM   #2491
MITsound is offline MITsound  Canada
MITsound's Avatar
Any particular reason not to make them 4 or 8 ohms?
Something to do with phase angles in a passive crossover to a dynamic driver?
"Aim above morality. Be not simply good; be good for something." HD Thoreau
Old 16th May 2018, 01:05 PM   #2492
JonasKarud is offline JonasKarud  Sweden
JonasKarud's Avatar
Its not that they are at 5 ohm that is important, its that they have identical values.
So, for example, that they will have the same voltage sensitivity...
Reality is just a word....
Old 16th May 2018, 02:20 PM   #2493
vemsom is offline vemsom  Sweden
Awesome Jonas!
Old 17th May 2018, 07:47 PM   #2494
fotsinijts is offline fotsinijts
Originally Posted by JonasKarud View Post
Here's some pictures of my new dipole tweeter. The membrane is made of 8 uM alu laminated to Mylar. Usable frequencies: 1,5 to 35 kHz.
It took me 3 years to come up with a method to produce perfect 5 ohm tracks!
The membrane is only attached at the short sides, which lowers the distorsion.
Cool possibility: Using the visible ends of the red protecting rods to indicate date of production in binary form!
Wow these are really neat! Is there a topic about these somewhere, would love to build something similar!
Old 18th May 2018, 08:35 AM   #2495
JonasKarud's Avatar
No topic, what I know of....
But if You have a 3d printer, I can send the STL files for the magnet holder assy and the front baffle. The magnets are:
Q-40-10-10-N: Block magnet 40 x 10 x 10 mm - supermagnete,
Six of them in each tweeter.
The big problem are the membranes, they are a pain in the to make....
Old 18th May 2018, 08:52 AM   #2496
Cool, I have a 3d printer so that part is covered. I also have acces to a lasercutter that would maybe be handy for making the membranes?
How did you made them? They look really neat
EDIT: Plotting would maybe be better I think
Old 18th May 2018, 01:38 PM   #2497
JonasKarud's Avatar
The membranes are made by cutting a self adhesive foil and then use this as an etch mask. I've tried different lasers/methods, but they are useless on this thin material.
Ultimate Open Baffle GalleryHide this!Advertise here!
Open baffle or no baffle for nearfield full range monitors? mdevelde Full Range 19 18th November 2016 04:26 PM
Ultimate Open baffle for tannoy red 15 inch murphythecat8 Full Range 20 30th January 2013 12:29 AM
Upwards aligned open baffle? ( pop box meets open baffle ) OllBoll Full Range 3 28th March 2011 01:00 AM
