Ultimate Open Baffle Gallery
Old 7th August 2017, 08:56 PM   #2341
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally Posted by Deano452 View Post
Are you using an Android or an IPhone?
I have an iPhone 5, but it is not in use, and was only ever used for voice & text (and for text i prefer using the computer which has a real keyboard)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 8th August 2017, 12:25 AM   #2342
MITsound is offline MITsound  Canada
MITsound's Avatar
Default 3 part stack
Electrostatic panels, atop Revelator in sealed cabinet, atop U Frame bass bins.
Incomplete veneering, was unsure it would sound as good as hoped.
Thanks, Dave.
There's a lot of free resize phone apps.
"Aim above morality. Be not simply good; be good for something." HD Thoreau
Old 14th August 2017, 10:51 PM   #2343
MITsound's Avatar
Default More hybridization
As long as I'm mixing and matching, I fixed a little lack of electrostatic resolution and dispersion, with a sealed back ribbon.
They cross about 10,000 hertz first order, and the amp powering them is actively crossed at 1200 hertz, 4th order.
I did try a dipole BG planar here, but the ribbons have some colouration I prefer. Also added a backfiring dome tweeter, but couldn't hear a difference, and took it out.
I don't have any way to measure these, but they sound less bright than just using a ribbon, at a 3000 hertz crossover, and are lots more resolving, on and off axis.
Quite a lot more complex than the simple setup I hoped would work on the long haul for me, I'd envisioned a U Frame sub with the 505 mini panels sitting on them.
I'm disappointed I couldn't get these to work as all open baffle, but the Revelators just don't sound as good that way, as they do sealed.
Bass, upper mids, and most of the treble are preserved as open back, however.
Old 4th September 2017, 07:40 PM   #2344
MITsound's Avatar
Default Front and back.
A little smoother than the ribbons, a neo3 seems as detailed as the Founteks, they just don't "stick out", I always hope for a speaker which is good, full range, never drawing attention to one frequency range, over others.
This is a small improvement, but I can't tell if it's a better tweeter, or a better match with its backless radiation pattern.
Old 7th September 2017, 06:30 AM   #2345
bibigon is offline bibigon  Ukraine
Well, I just finished making open baffles. This is my own design.
Old 7th September 2017, 08:52 AM   #2346
gadut is offline gadut  Indonesia
gadut's Avatar
that is nice, bed style
Old 7th September 2017, 08:57 AM   #2347
why bed? rather a throne! ))
Old 7th September 2017, 07:14 PM   #2348
Kjeldsen is offline Kjeldsen  Denmark
Excellent woodworking skills
http://kjeldsensforbindelser.dk
Old 7th September 2017, 07:55 PM   #2349
kec is offline kec  United States
kec's Avatar
WOW! Awesome!
MSI E350IS mITX > Foobar > SPDIF > Denon A7100 preamp > Crown XLS1000 > ?
Old 8th September 2017, 01:24 AM   #2350
pompon is offline pompon  Canada
Good works!
Ultimate Open Baffle GalleryHide this!Advertise here!
Open baffle or no baffle for nearfield full range monitors? mdevelde Full Range 19 18th November 2016 04:26 PM
Ultimate Open baffle for tannoy red 15 inch murphythecat8 Full Range 20 30th January 2013 12:29 AM
Upwards aligned open baffle? ( pop box meets open baffle ) OllBoll Full Range 3 28th March 2011 01:00 AM
