Ultimate Open Baffle Gallery
Old 20th August 2013, 06:40 AM   #1021
Kjeldsen is offline Kjeldsen  Denmark
There is a "tunnel" behind the fostex. It should be chamfered
Old 20th August 2013, 03:42 PM   #1022
ScottG is offline ScottG  United States
Yup!
perspective is everything
Old 20th August 2013, 04:37 PM   #1023
4Torr is offline 4Torr  United States
Maybe a felt or foam lining inside the tunnel would reduce the standing wave and edge diffraction.
Old 20th August 2013, 05:59 PM   #1024
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
There is not enuff room to get a thick enuff chunk of either to be effective.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 20th August 2013, 11:45 PM   #1025
repeddler is offline repeddler  United States
Actually I did chamfer..... but maybe not enough??
I painted that part brown because I couldn't figure out how to veneer that angle. Do I need to go deeper and/or wider? That is 2 pieces 3/4" ply glued together.
Old 21st August 2013, 12:16 AM   #1026
frugal-phile(tm)
planet10's Avatar
Ideally the champher starts where the basket opens up.
Your baffle looks pretty thick, and would benefit from more champher.
dave
Old 21st August 2013, 01:55 AM   #1027
gainphile is offline gainphile  Australia
gainphile's Avatar
Celestion System 6000 loudspeaker system
Monopole Mid-High with dipole subwoofers. Circa 1996
www.stereophile.com/floorloudspeakers/892/index.html
http://gainphile.blogspot.com
Old 21st August 2013, 04:16 AM   #1028
dave
Yes, exactly.
This is a good thing to know, especially with low mass full-range drivers where the resulting resonance can seriously disturb both the linear behavior of the driver, and its non-linear behavior (..and always in a negative fashion). Even most woofers should have this feature, but particularly full-range drivers and mids or dipole planar tweeters.
Sometimes the best method is a "lay-up" of 1/4 panels rather than one thick board so you can move the next successive layer of 1/4" board an inch or more away from the driver - increasing the opening (..and continue the "expansion" from there). Then you can use a router to angle those edges of each board. (..visually sort of an inversion of a Mayan Pyramid's "steps" with the rear opening getting wider and wider.)
Old 21st August 2013, 04:21 AM   #1029
GT Audio Works Capital Audiofest - YouTube
Old 21st August 2013, 05:50 AM   #1030
It's probably fine as is. You chamfered. These guys will have you going for years with suggestions and opinions.
Ultimate Open Baffle GalleryHide this!Advertise here!
Open baffle or no baffle for nearfield full range monitors? mdevelde Full Range 19 18th November 2016 04:26 PM
Ultimate Open baffle for tannoy red 15 inch murphythecat8 Full Range 20 30th January 2013 12:29 AM
Upwards aligned open baffle? ( pop box meets open baffle ) OllBoll Full Range 3 28th March 2011 01:00 AM
