When considering the port length for a vented box, does the measure refers the length from the outside of the box (the real duct legth), or the length of the part of the port that goes inward (considering a distance from the internal surface of the wall where the port is)?
#2 |
Hi, the real duct length,
#3 |
Make sure whatever method you are using has an end correction of some sort or the box will likely be tuned too low. What is this for and what kind of stuffing or wall lining are using? Is the port flared or straight?
#4 |
The port is a Monacor BR-30HP. I guess that the internal diametre is constant, although it doesn't appear so. I assume that because it only specifies one internal diametre. It seems that the port is flared at one end and the walls tend to get ticker to the outside direction.
I'm not using any filling or lining. |
| port length | jwhit67 | Multi-Way | 1 | 6th March 2008 12:29 PM |
| Help with port length please | Bobhof | Multi-Way | 3 | 2nd May 2006 06:32 PM |
| Port Length Question | 69stingray | Multi-Way | 1 | 29th April 2006 08:13 AM |
| port length | dave k | Multi-Way | 13 | 13th July 2003 02:32 PM |
| Port length question | masterp2 | Multi-Way | 40 | 12th February 2003 02:39 PM |
| Page generated in 0.07421 seconds (82.13% PHP - 17.87% MySQL) with 10 queries |
