Notch Filter Necessary for 3" HT Center Channel?
Old 21st May 2008, 12:56 AM   #1
sdclc126 is offline sdclc126  United States
sdclc126's Avatar
Default Notch Filter Necessary for 3" HT Center Channel?
Hi -
I am wondering if a notch filter is necessary for a 3" single driver center channel application, considering the human voice doesn't reach anywhere near the breakup frequencies of the drivers considered:
http://www.madisound.com/catalog/PDF/830986.pdf
Or, perhaps an inductor above the voice range but well below the breakup, just to roll of the response some?
Anything I'm missing? (I usually am. )
Soft Dome
Old 21st May 2008, 11:07 AM   #2
R.I.P.
Default Re: Notch Filter Necessary for 3" HT Center Channel?
Maybe I'm missing something but the centre channel is not just speech ?
(I do not have a multichannel system)
/sreten.
Old 21st May 2008, 02:43 PM   #3
sdclc126's Avatar
Well for 5.1 HT etc. yes it is primarily the voice channel. I'm sure not purely but mostly. For a music channel/music listening I would definitely filter but for HT I'm not a purist.
There is probably little enough info in the CC speaker other than voice that I'm thinking it would be insignificant in the breakup regions of these speakers, especially the Peerless as it's higher up than the Hi Vi. The Aura 3" is even higher but these are out of stock at Madisound, along with all their other small drivers, otherwise I'd consider it.
Soft Dome
Notch Filter Necessary for 3" HT Center Channel?Hide this!Advertise here!
Notch filter godless Multi-Way 5 22nd April 2008 10:26 AM
1x10" bass guitar monitor with variable port tuning and notch filter? alexclaber Multi-Way 7 1st April 2008 07:24 PM
need help wana change 60-Hz twin-T notch filter to 279 Hz filter prorms Solid State 0 10th February 2008 12:38 AM
Can Zaphs notch filter be used without the BSC filter? GuyPanico Full Range 0 21st July 2007 02:27 AM
Foam blocks between 2 Tang Band 3" full range on a small center channel The Paulinator Multi-Way 5 27th March 2003 06:04 AM
Copyright ©1999-2017 diyAudio
