diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Multi-Way (http://www.diyaudio.com/forums/multi-way/)
-   -   What advantages running ported midbass if you are running a sub? (http://www.diyaudio.com/forums/multi-way/123407-advantages-running-ported-midbass-running-sub.html)
mitchyz250f 20th May 2008 12:46 PM
What advantages running ported midbass if you are running a sub too? Is there an increase in sensitivty?
I have read where people tune to lets say 80 and set the crossover at 80. Does this mke sense. ?
gni 20th May 2008 01:10 PM
It can keep the response of the mid driver smoother. . . usually
the port will split the resonant peak into two smaller
peaks keeping the response smoother and gives the driver
a better roll-off at the bottom end. . .
The best type of sub + main speaker systems have the mains that
can produce the low frequencies well. . .they usually have a smoother
roll-off and sound more natural. . .the mains are still going to be
getting some of the frequencies due to the cross-over slope being
12 dB/Oct or 18 dB/oct or 24 dB/oct or higher but it is still not
an infinite brick wall that separates the two. . .both the sub and
the mains need to be able to produce the frequencies two or
three octaves beyond the crossover point. . .
gtforme00 20th May 2008 02:20 PM
A ported alignment will create a 18db/oct (3rd order) acoustic filter below the tuning frequency, a sealed enclosure will create a 12db/oct (2nd order) acoustic filter below the tuning frequency. Either of these can be used along with electric filters set at or near the tuning frequency to create a steeper effective acoustic filter.
In my personal experience, I find it easier to blend a sealed enclosure with a subwoofer.
There are two other advantages of a sealed enclosure that may or may not be important to you.
1. They are usually physically smaller.
2. If you choose not to run a high pass filter to the mains (not recommended), they provide better protection against large excursions at low frequencies. A ported box does not substantially load the woofer below the tuning frequency and will provide little protection against over excursion of the woofers.
David
Conrad Hoffman 20th May 2008 02:34 PM
I run an open baffle mid bass, but I think sealed is the easiest solution. A ported system will have phase shifts that make the crossover design far more difficult.
Resources saved on this page: MySQL 18.75%
