I want to try a SuperTweeter, one like
http://www.tannoy-speakers.com/s.php...le=ST100&s=30. I would try to build one myself but need some tip about what element I can use. Regard Progg70 |
#2 |
Looks like a reverse engineering project. . .I would suggest
keep it simple and try to match it to your existing loudspeaker instead of having multiple SPL taps and top end limiting shelves. . . It is very cool item. . .must cost $$$$ |
#3 |
I need suggestions about what I can use for speaker.
#4 |
Grettings Progg, I would use either a three quarter inch metal dome, a ribbon tweeter, or a small planar dynamic unit such as HI-VI's RT1II.
#5 |
The Hi-Vi RT1-II would make a terrific supertweeter - it has good off-axis response well above 20 khz.
If you want something cheap and simple, the Aurasound NT1 would work nicely. |
#6 |
This might be of some use to you. Hans Hilberink did a similar project using the Tannoy supertweeters as inspiration.
- JP |
#7 |
Thanks!
The link was nice but Peerless don’t make them anymore. I have problems to find EU dealers for the Hi-Vi RT1-II. Any more suggest for more known speaker labels. |
#8 |
Dayton ND20FB-4 ($6) : ![]() Pretty good for $6 ! postage should not be too much. http://www.lautsprechershop.de/ sell the ND20FA-6. |
#9 |
Fostex FT96H or similar? About 60% the price of their "enclosed " supertweeters.
Also looking elsewhere (follow sreten's link), they have a listing for supertweeters under "ribbons". A few options there, including HiVi Research. stew
stew ☮ -"A sane man in an insane world appears insane." |
#10 |
Greetings Spasticteapot, I believe the HI-VI unit is used is used in Audiosmile's outboard supertweeter and should have excellent horizontal dispersion.
| Looking to build some speakers | godless | Multi-Way | 55 | 3rd January 2010 12:24 PM |
| Build speakers with low sensitivity | unsolved | Instruments and Amps | 11 | 16th January 2009 10:03 PM |
| build my first speakers | dcdj | Multi-Way | 1 | 21st March 2006 01:01 AM |
| Newbie wants to build first set of speakers | tacomaboy | Multi-Way | 15 | 14th January 2004 02:36 AM |
| Just build my first speakers ... | greg7 | Multi-Way | 3 | 14th May 2003 02:43 PM |
| Page generated in 0.10019 seconds (79.36% PHP - 20.64% MySQL) with 11 queries |
