Old 17th May 2008, 11:46 PM   #1
m@ is offline m@  Thailand
Default New Translam Bookshelf Project - Based on a Zaph Design
I've just finished a translaminated cabinet build based on one of Zaph's published designs (the 5.5" metal SEAS project).
I've tried to document it well to share some of the mistakes I made along the way.
Lots of thanks to Zaph for publishing all of the information that he does - he's been a big help to me and I'm sure many others.
Forgive the photos - I'm not a photographer and I really don't want to learn (too much else to do).
Peace
http://www.accidentalpublicist.com/p...%20Project.htm
For a long time, I've felt that the difference between an "objectivist" and a "subjectivist" is that the latter has had at one time in his or her life a mentor who could show them what to listen for. -- John Atkinson
Old 18th May 2008, 12:16 AM   #2
ShinOBIWAN's Avatar
I always like the striking visuals of laminated ply layers.
Nice build.
Old 18th May 2008, 12:30 AM   #3
JLC7 is offline JLC7  United States
They look wonderful!
I envy your patience with the jigsaw. I'd go nuts cutting the layers one by one inside and out.
Old 18th May 2008, 01:54 AM   #4
R-Carpenter's Avatar
Send a message via ICQ to R-Carpenter
Yaaiks, that's allot of work! Very professionally done. Good jig for the router. Phenomenal looking pair of speakers, nice job!
For thous who like this look but not prepared to do quite as much machining, zebra wood veneer or a reconstituted zebra veneer will create similar look.
Old 18th May 2008, 02:31 AM   #5
peter_m is offline peter_m  Canada
Pretty!
Congrats!
I am jealous!
Old 18th May 2008, 03:23 AM   #6
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Fantastic woodwork! Probably some notches up in musical information too, due to reduced structural noise VS the original project's simpler cabinet.
Old 19th May 2008, 07:46 PM   #7
Default thanks...
Peeps,
Thanks a lot for the feedback.
1) They're not that professionally done - the lines are quite off if you sight them. If anyone does a project like this, use a stable template! Will make a world of difference. Also, add holes in the template so you end up with alignment / clamping holes - would have made short work of getting a perfectly straight cabinet.
2) It's not really that much work if you're doing a bookshelf. When you figure cutting, bracing, and curving a normal cabinet I can't imagine a simpler way than this.
Matthew
Old 20th May 2008, 12:04 AM   #8
Really nice build. congrats
Qty. 5 zaph sr71 bookshelf monitors for sale mp006ltk Swap Meet 4 22nd February 2010 10:34 PM
Speaker idea based on Zaph ZD5, thoughts please, Zaph? wigginjs Multi-Way 23 3rd April 2009 05:09 AM
Troels VS. Zaph - 2 Way Bookshelf Showdown harrisni Multi-Way 24 2nd April 2008 04:40 PM
Beginner bookshelf project? excetara2 Multi-Way 2 9th July 2006 04:00 PM
Page generated in 0.10039 seconds (75.49% PHP - 24.51% MySQL) with 10 queries
