I was curious if anyone has looked into what effects removing the rear chamber on a tweeter like the Seas 27 series tweeters would have. The reason I ask is that I would like to use a large format tweeter in the A-pillar in my car but I don't have the depth. There is still enough room to add damping material behind the vented pole piece so it would be like an open baffle of sorts.
I would assume it may lower Fs somewhat and change the Qts but the Fs is already so low, ~500hz for the Seas, that as long as you take into account the new roll-off profile in the crossover I think it should be ok. With a x-over freq of ~2k there will be no concern of over excursion, so what do you think? |
#2 |
Can you take the chamber off without removing the magnet too? It all looks like one piece to me.
#3 |
#4 |
The chamber is just glued to the metal back plate.
I prefer the performance of the seas tweeters and with the low Fs, the ability to crossover low. I also already have a pair. |
| So, what exactly does a compression chamber do?? | NV&H | Full Range | 2 | 5th February 2006 12:40 AM |
| Separated or Same Chamber Box? | suprastar17 | Subwoofers | 2 | 19th April 2005 02:32 PM |
| If I removed the rear chamber of an electrodynamic tweeter to enable dipole operation | 454Casull | Multi-Way | 9 | 26th July 2004 03:04 AM |
| Water chamber sub | Guss | Subwoofers | 42 | 1st December 2003 01:58 AM |
| Page generated in 0.09061 seconds (70.48% PHP - 29.52% MySQL) with 10 queries |
