Old 17th May 2008, 05:52 PM   #1
Question Hi, and midbass recommendations that play low.
Hi
My name's Tim and I'm new and i'm looking for some recommendations from you clever lot!
I'm currently prototyping my first proper speaker build.
So far I have the midrange sorted, hybrid legatia L4's in transmission line enclosures (I know many of you may frown on car audio stuff, but this isn't your circuit city type of kit!)
http://www.hybrid-audio.com/Legatia%20L4.pdf
It's a 4" driver that is currently crossed at 120hz and coping all the way up to 16khz easily, i don't know if it's playing higher as that's where my hearing stops :lol: the sound is beautifully spacial and detailed and very neutral.
I'm looking for a suitable driver to take my speakers all the way down REALLY low, i'm completely against seperate subwoofer "solutions" unless they're doing silly 10hz style stuff.
Budget, hmmm ideally no more than £200 a pair, unless it's worth it.
maximum cabinet size - infinitely negotiable, long gone are the thoughts of little standmounts. Using a behringer UD for getting the crossovers right before building them, Power available - enough
So what can you guys recommend to me, looks like a top forum and has the best rules page ever!
Tim
Old 17th May 2008, 09:48 PM   #2
5th element's Avatar
You don't say how loud you want it to be able to go. If EQ is available lots of drivers will go suitably low.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack!
Old 18th May 2008, 06:32 AM   #3
Loud...
hmmm, I want something that will be able to wobble me a little bit, but i'm not gonna go crazy I'm sure i'll be living in pokey size living rooms for a while yet and i've got some old jamo's for parties
I'll be more than happy with anything over 105db i'm fairly sure.
Old 18th May 2008, 02:13 PM   #4
GM is offline GM  United States
GM's Avatar
Greets!
Since you already have a TL, then a matching TL seems the reasonable choice, so find a however low Fs driver you want to 'reach' with at least as high a Qts as the L4's except with a few dB higher efficiency to help offset baffle step loss (BSC) based on the L4's ~86.7 dB/W/m calc'd efficiency.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 19th May 2008, 03:05 AM   #5
To say i was left completely baffled by the opening page of martin kings page would be an understatement.
And the only really suitable driver i could find according to the above information was
http://www.partsexpress.com/pe/showd...number=297-058
anyone have any input on this driver? or enclosure designs?
Thanks!
Tim
a big toy to play with.... angeloitacare Multi-Way 64 10th May 2012 01:39 AM
Is there a nakamichi MB-100 mod to play CD-R's? whiterabbit Car Audio 14 17th March 2009 08:11 PM
can't play stereo yngwie Solid State 2 17th August 2007 05:05 AM
6.5/7inch midbass recommendations AntM Multi-Way 13 31st May 2005 06:52 PM
Let's Play 'Dump the Cap' EchoWars Solid State 15 21st February 2003 12:04 PM
Page generated in 0.07885 seconds (75.52% PHP - 24.48% MySQL) with 10 queries
