Old 13th May 2008, 03:29 PM   #1
Juggy is offline Juggy  Canada
Default RCL, RL, Zobel.
All,
I've been reading, and am a little confused as to when we use which filter.
From what i understand,
The RCL is generally used on tweeters because of the large inductor that would need to be used in a zobel.
A Zobel is generally used on woofers and mids to compensate for the rise in impedence at Fs.
I've seen RL and RC filters as well, can someone please shed some light on those filters and their use as well?
Thanks again and i apologize for my basic questions.
Old 13th May 2008, 04:39 PM   #2
Horexx is offline Horexx  Germany
In detail:
http://users.ece.gatech.edu/~mleach/...obel/zobel.pdf
Old 13th May 2008, 08:57 PM   #3
Svante is offline Svante  Sweden
Svante's Avatar
The main reason to use impedance equalizing networks is that a frequency dependent impedance sometimes causes problems for the crossover filter.
Basic filter therory usually relies on a purely resistive load, and using impedance equalization can be a way to achieve that. In that case, textbook filters behave more like the theory predicted.
Today, when simulation is so easily available for anyone with a computer, the need for impedance equalization is less. One can mostly modify the filter to behave as desired without these solutions.
Anyway, to answer the question:
An RC link compensates for the rise of the impedance toward high frequencies caused by the voice coil inductance. There is rarely a need to do this.
An RCL link compensates for the impedance peak at resonance. This can be useful for tweeters; the system resonance is often (too) near the crossover frequency and it may be hard to make the filter behave well without the compensation.
An RCL link can also be used on woofers that are crossed over low (100-300 Hz), also due to that the resonance is near the crossover frequency.
I encourage anyone to try some simulations on this. It is rather enlightening to put a cookbook filter and connect it to a real loudspeaker impedance.
All the above is for passive filters.
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
Old 14th May 2008, 01:12 AM   #4
Send a message via AIM to 69stingray Send a message via MSN to 69stingray Send a message via Yahoo to 69stingray
Info on Zobel Networks:
http://www.trueaudio.com/st_zobel.htm
Zobel Calculator I like to use:
http://www.the12volt.com/caraudio/crosscalc3.asp#cc
Series Notch Filters (RCL):
http://www.carstereo.com/help/Articles.cfm?id=23
Audio DIY Page
FOLLOWMY529.COM - Subscribe and follow the performance of my daughter's 529 College Saving Account.
Zobel Or No Zobel ? sakis Solid State 74 2nd March 2012 09:32 AM
Do I need a Zobel ? chasingame Multi-Way 22 7th August 2009 11:45 AM
which cap do you like in zobel ? sandro600 Solid State 2 28th January 2007 10:36 AM
zobel Streets97f Subwoofers 4 19th November 2006 04:44 AM
Page generated in 0.09266 seconds (76.35% PHP - 23.65% MySQL) with 10 queries
