having lived with cheap OB system for quite sometimes and enjoy its characteristic, I am intrigued what has been said about Linkwit's pluto. It looks small enough for my room and many have compared it to the much more expensive Orion (cost $2000 just for the drivers).
being experimental, I need to make this as cheap as possible so the approach will be:
- no PCB, simplified diagrams - $44
- PVC, etc is not expensive - $50 from bunnings
- 4 channel gainclones already available - $0
- I have spare 5" drivers but not the peerless (P13WH)
Unfortunately Aura NSW2 tweeter is specific and needs to be imported from the US $80 including shipping.
Hopefully someone can point me to the right direction here
You can simulate most if not all the filter requirements using DCX2496, saves time and headache and QUICK, by just pushing the button.
I mention this before in previous forum, if you like the speaker design and the sound appeals(different type of drivers give different sound even the x-over maybe the same) to you then build the passive equivalent if you care or incline to.
go to Ebay in the States, you can get one at a good price/cheap, the resale value of this unit is very good, quickly snap up, and don't lose much money.
I am still using mine. You will not regret it, some people use them permanently by upgrading it approx. US$250.
cheers... happy speaker developing.
I starting developing speakers as a hobby amore than 6 months ago.
This is my experience, you can take it what you like.
I believe there are a few things you need that will make your speaker development/redesign(following Linkwitz design by changing drivers is considered as a redesign) smooth and effective.
1. An active, digital x-over, DBX,Behringer etc. hence avoid lots of soldering and resoldering, very time consuming.
2. Microphone for measuring the freq response, microphone and preamp combo is quite cheap. you can get free s/w from the the net eg.ARTA. I was able to use Soundeasy(SE) s/w from a friend.
3. s/w that will allow you to design passive x-over as well. There free s/w available as well, SE can do that too. SE is not cheap, but very powerful.
One drawback there is a learning curve for all the above.
cheers.... happy development.
new project..
A suggestion, rather than building the Pluto, you want to look at this project, it looks interesting to me and cheaper. It will use passive x-over, and high spl, >=92dB.
http://www.htguide.com/forum/showthread.php4?t=29988&page=1
It will be dynamic and open, the bass(ported cabinet/enclosure) may sound different to an open baffle bass.
Yes I've tried few variants of OB such as u-frame, h-frame, also hybrid with closed box. However I always went back to simple OB within a day or two. There is something about that deep clean OB bass.
Was interested in aether's look as well but that still need a fairly sizable room. My study room is only about 3x4m in size and pluto seems so smal it would fit right in.
Anyway I've finished the active xo, well almost silly me I forgot to buy 2.7nF ...
Yes after some torturous wait the AURA NSW2 are back on the shelves. Mine are leaving Madison, WI as we speak, destination: Melbourne
For the woofers australian shops actually still stock the original nomex peerless which already discontinued in the US. But I have a pair of P13WH which should do the job fine (I think). I don't have measurement kit which makes it difficult.
The physical build of the Pluto is very easy. PVC easily cut with handsaw. The pair is mounted on paving block which is significantly heavy. The bases are simply glued using that silicone stuff which seems very sturdy and strong after few hours. I added the length of the pipes by 4.5" just to adjust the base height differences with original plutos and to experiment with them. They can easily be cut later.
Challenging part was mounting the woofers. I did not want to simply glue them, so had to construct a ring. They started with two circular cutout with different diameter, the inner fits the rubber mounting and clamped, then cut holes throught it using jigsaw. I'll post a closeup of it later.
I fitted some spare tweeters and woofers I have laying around. Initial impression is very promising. Although it's basically a closed box woofer they don't project that narrow closed box feeling. They sound open like OB. Bass seems to go quite deep but far from perfect, understandably the woofers have not even been screwed in
The much-waited Aura tweeters shipped from Madisound the US. They only cost $16 each but shipment is more expensive than the tweeters themselves.
Fitted... First impression is these speakers are very close to dipole sound but that had been much discussed in linkwitz pages to the extent that he felt the need to 'fix' the orion. What I did not expect though, was how deep the bass goes. Not as deep as my current OB but close, and nearly as uncoloured.
The drivers are crossed at very low 1kHz (hence the special tweeters) and behaves omni-directionally up until 3kHz, after which it becomes forward directional.
Here is the listening room (experimental). Their small footprint made it very easy to move around to obtain that 1m-from-the-wall magic distance. Something very difficult to do with huge dipoles. I ended up having less than that though, as my room is really small.
Few to be done as I am using a different woofer (Vifa P13WH instead of Peerless Nomex) and need to adjust the xp, but for the moment I am impressed with the accuracy of these sewer-pipe speakers in reproducing live stages. We'll see in the next few weeks if I will have the itch to put my OB bass back.
True to the spirit of Linkwitz builders, anyone in melbourne interested enough to hear them is welcomed. When it's done of course ...
- my Pluto build diary (aussie)
