Old 12th May 2008, 03:44 AM   #1
jaya000 is offline jaya000  India
Default Mmd?
Some say Mmd means diaphram weight ,
Some say Mmd means recone kit assembly/full cone assembly weight
Some say Mmd means recone kit assembly/full cone assembly weight less half weight of surround.
Which is proper?
Old 12th May 2008, 04:01 AM   #2
Mmd = diaphragm weight, including voice coil.
Both the original cone and replacement cone should weigh about the same, so there shouldn't be a problem there.
As for the surround-I doubt it weighs very much in comparison to the diaphragm and voice coil, so I wouldn't worry about it.
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Old 12th May 2008, 05:22 AM   #3
The cone comes with surround. So u mean to say that we must include the full surround weight.
The recone assembly means cone, voice coil, spider dust cap & glue.
Old 12th May 2008, 06:33 AM   #4
Default Re: Mmd?
Which is proper?
Hi jaya000,
Mmd is the total mass of those components of a drive unit that actually move when a signal voltage is applied to the voice coil. Because the spider and surround are fixed at their outer edges, the general rule is to include half their masses only.
Therefore Mmd = mass of (voice coil + 1/2 spider + cone + dust cap + 1/2 surround + glue)
Hope this helps.
Kind regards,
David
Old 12th May 2008, 07:25 AM   #5
Thank u very much David McBean!
U hv clarified it in the very nice way.
Page generated in 0.06743 seconds (74.55% PHP - 25.45% MySQL) with 9 queries
