Old 10th May 2008, 01:05 PM   #1
Default Mismatched Speaker Impedance
I am new at audio and would appreciate some advice.
I am building a battery powered speaker. The amp will work with 4 and 8 ohm speakers.
Can I use a 4 ohm on one channel and an 8 ohm on the other?
Thanks,
Carl
Old 11th May 2008, 02:03 AM   #2
For the same volume setting, the 4 ohm side will be taking 2 watts from the amp for each watt the 8 ohm side takes.
The 4 ohm will also be slightly, (3 dB) louder.
If that doesn't bother you, I see no reason you can't do it.
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Old 11th May 2008, 04:44 PM   #3
Thanks for the help.
Carl
Mismatched drivers in IB subs mashaffer Subwoofers 1 22nd March 2006 05:56 AM
Slightly mismatched channels lumpylipton Pass Labs 0 26th February 2006 06:38 PM
Mismatched drivers in output stage - is this a problem? Dave S Solid State 17 29th November 2005 09:30 AM
Speaker impedance not what it seems? annex666 Multi-Way 9 8th September 2003 12:13 AM
Speaker Impedance RobPhill33 Multi-Way 2 14th January 2003 07:55 PM
Page generated in 0.09779 seconds (48.97% PHP - 51.03% MySQL) with 10 queries
