Old 27th January 2009, 12:54 AM   #21
Thanks scalero for the photos. Do you happen to have one of the back of the front baffle? Just curious...
Twangbar
Old 28th January 2009, 08:06 AM   #22
scalero is offline scalero  Spain
no, sorry
Old 28th January 2009, 11:41 AM   #23
but I found one of the SCM 20SL.
You can see more on http://www.mhennessy1.f9.co.uk/atc/
Old 28th January 2009, 11:56 AM   #24
I have several photo of mi ATC SCM 50 clone
Old 28th January 2009, 12:02 PM   #25
Another one
Old 28th January 2009, 12:03 PM   #26
With drivers
Old 28th January 2009, 12:06 PM   #27
Here are the two box one above other. The top box is a scm 50 with 50l without medium or tweeter
Old 28th January 2009, 12:08 PM   #28
Making the last box
Old 28th January 2009, 02:01 PM   #29
schauki is offline schauki  Austria
Hello!
Which is the original tweeter in ATC Speakers? (Model Nr?)
Are the different frot type to type?
regards
schauki
Old 28th January 2009, 05:15 PM   #30
The SCM50/ SCM100 used the old model Vifa Ferrofluid-cooled Soft dome 25mm (one inch) tweeter, which i presume made to order per ATC specification, unkown type/ model - probably similar to D25-TG-05-07. That was before 1997/8??.
The newer model, especially SCM50 SL PT / SCM100 SL PT 3-way passive monitor floor standing system uses Seas Excel either T25C-003 (E036) or T25FC-001 (E006) and for sure not a Millenium T25C-002 (E011).
See below information that I recently found ATC catalog/ brochure on Japaneese
http://www.electori.co.jp/atc/SCM50SLPT.pdf
http://www.electori.co.jp/atc/SCM100SLPT.pdf
I am pretty sure for this. See the picture of the tweeter.
Modifying an Original Richter scale crossover ??? scutterflux Solid State 2 30th June 2008 06:06 PM
Celestion 7 (original, not MKII) crossover markiemrboo Multi-Way 0 20th February 2007 12:25 PM
Mark Levinson no.29 clone? schematics available! kasra Solid State 2 23rd November 2006 11:05 PM
adapting original passive crossover keyser Multi-Way 0 22nd February 2005 10:49 PM
Position of Crossover in ProAc 2.5 Clone Alain Multi-Way 1 25th April 2003 02:18 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
