original crossover schematics for clone ATC SCM 100
Old 8th January 2009, 02:13 AM   #11
TwangBar is offline TwangBar  Canada
tamariska - keep us updated with your progress. I would be very curious on see your results.
Old 24th January 2009, 03:46 AM   #12
tamariska is offline tamariska  Indonesia
Twangbar. Sorry for the slow respond. The project is still on developing stage - so it needs some time to run.
For woofer, finally i bought a pair of volt B2500 from solen. It costed around $800 a pair plus $250 shipping and $200 customs etc. Well quite expensive but i think its worth.
For tweeter, i realize R29.7000 here locally is still expensive at approx $800 a pair (discounted price), so for the budget sake i would change my mind on going with Seas Millenium T25CF002 or probably SS 9900. Can you advise which one is better?
So the configuration will be B2500 + SM75-150 (non s version 16 ohm) + T25CF002 (or SS 9900).
Cabinet will be tuned at 70L or so. Do you have such autocad design drawing with internal bracing (to follow to SCM50 model) ?> Thanks
Old 25th January 2009, 02:47 PM   #13
Tamariska - Sounds like you are well on your way. I used the Seas T25C003 - which is what I think ATC uses. It is the the non-ferrofluid version so it is a bit more efficient (91 db).... and not too expensive! Harbeth also uses this model so it must be good eh?
As for the SCM50 box - as stated elsewhere, the "50" denotes it's volume in liters. Also, I think I have read the their box is not internally braced... but I could be wrong. I think also that it is stuffed with insulation... so it may act more like a larger box. Anyway, bracing in my mind is always good..... maybe use the golden ratio for determining position?
My (modified Proac Studio Tower) box using the ATC woofer is 65L and is braced. I modified it by building a new front baffle out of 3 layers of 3/4" MDF and put in one brace between the mid and the woofer. I'll try and post a picture.
Twangbar
Old 25th January 2009, 03:06 PM   #14
Here are some pics of my SCM50 clone. The port looks ugly because I am still sorting out the tuning so I made it so I can remove it. The molten tower beside it is my Aleph 2 clone.
Old 25th January 2009, 03:09 PM   #15
Another picture. The bottom of the cabinet (under the baffle) is a separate cavity which you can fill with sand or lead.
Old 25th January 2009, 03:14 PM   #16
Another photo of the back. I have the mid and tweeter network mounted on the back for continuous tweeking..... the woofer network is in the cabinet.
Old 26th January 2009, 07:22 AM   #17
scalero is offline scalero  Spain
I Have a pair of photos inside ATC SCM 100
Old 26th January 2009, 07:24 AM   #18
Now, inside
Old 26th January 2009, 07:28 AM   #19
Another.
You can see the bitumen
Old 26th January 2009, 07:29 AM   #20
Last photo
original crossover schematics for clone ATC SCM 100Hide this!Advertise here!
Celestion 7 (original, not MKII) crossover markiemrboo Multi-Way 2 7th November 2016 10:39 PM
Modifying an Original Richter scale crossover ??? scutterflux Solid State 2 30th June 2008 06:06 PM
Mark Levinson no.29 clone? schematics available! kasra Solid State 2 23rd November 2006 11:05 PM
adapting original passive crossover keyser Multi-Way 0 22nd February 2005 10:49 PM
Position of Crossover in ProAc 2.5 Clone Alain Multi-Way 1 25th April 2003 02:18 AM
