Old 17th May 2012, 01:57 AM   #121
Ok - I made a stab at the layout of the xover based on the pictures posted. Note that I have labelled the changes in Red and marked the inductor numbers in blue and have also marked the colour of the wires used.
All the cap values are the same, but there are some resistor values that have changed as well as an additional resistor added to the tweeter network before the 184 inductor.
If anyone else can check my work, that would be great.
Old 17th May 2012, 02:03 AM   #122
I would but I cant open the first pic of the front of the board .
Chris
Old 17th May 2012, 02:15 AM   #123
I have no problem opening it up, but I can post it again for you.
Old 17th May 2012, 04:04 AM   #124
Thanks,
Initially this did not work either so I logged out and back in again and now both links work . Couple of questions.. At the bottom of the pic of the front of the board the wires are covering the board and a bit of a jumble what is connected to what?
Also what are the dimensions of the board?
Chris
Old 17th May 2012, 07:05 PM   #125
Originally Posted by cafe latte View Post
Thanks,
Chris
The bottom wires are the output, starting from image right: Woofer is red, black. The middle wires are tweeter, which are white and yellow, and the left
are for the midrange, which are green and orange. The output corresponds with the input. Input connections at the top of the picture are also, from the right of the image, woofer, tweeter, midrange.
The board is just about 8" x 12".
Old 21st May 2012, 12:12 AM   #126
cafe latte- I measured the board for you and the exact measurement in our weird inch system is 8.25" x 13.25", or, to join the rest of the world, 210mm x 345mm.
Old 21st May 2012, 02:20 AM   #127
Thanks really appreciated. I want to draw a component overlay diagram so I have a plan for etching the boards. The only issue I had so far is were all the wires are bunched up at the bottom all the connections are not that clear. I am busy for the next few days, but I will get back onto it when I have time and hopefully it will be some use.
I wonder of the two circuit diagrams we have which is the most recent?
CL
Old 21st May 2012, 02:51 AM   #128
According to the seller, which of course could be fact or fiction, these xovers came from 2 year old SCM50s he had that had cabinet damage after a move. I saw that he had listed the woofers and mids on Audiogon etc. after the crossover sale. I've had them about 9 months.
Old 29th May 2012, 08:49 AM   #129
....and then there were two. Well, almost. Still need to install the binding posts and back.
Old 6th June 2012, 05:39 AM   #130
kompakt is offline kompakt  Germany
Hello!
Do i see correctly,that the poles of tweeter are reversed ?
Seyed
Modifying an Original Richter scale crossover ??? scutterflux Solid State 2 30th June 2008 06:06 PM
Celestion 7 (original, not MKII) crossover markiemrboo Multi-Way 0 20th February 2007 12:25 PM
Mark Levinson no.29 clone? schematics available! kasra Solid State 2 23rd November 2006 11:05 PM
adapting original passive crossover keyser Multi-Way 0 22nd February 2005 10:49 PM
Position of Crossover in ProAc 2.5 Clone Alain Multi-Way 1 25th April 2003 02:18 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
