Old 7th May 2008, 07:42 PM   #1
axiome is offline axiome  United States
Default crossover board repair
Hi there,
I recently had a speaker damaged and the crossover board snapped into 2 pieces. How difficult would it be to glue back together and fix? Luckily I have the other speaker's board full intact and working as a reference. I can do basic soldering but never fixed a board before. I could call up and just request a new crossover board but seems like a nice little challenge.
Old 7th May 2008, 07:48 PM   #2
Svante is offline Svante  Sweden
Svante's Avatar
Default Re: crossover board repair
Originally posted by axiome
Hi there,
It should be fairly easy, just solder the haves together and enforce the solderings with some naked copper wires. Make sure nothing rattles when the speaker vibrates.
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
Old 7th May 2008, 09:05 PM   #3
Any recommendations for putting it back together? I was thinking gorilla glue for the board itself. Then, something long and sturdy for the sides to reinforce it some more.
Old 7th May 2008, 09:56 PM   #4
Epoxy or CA glue will work.Strips of wood or circuit board material glued along the sides would be good,even metal strips will work,as long as there is no chance of shorting anything out.
When is a cross network more than a crossover board mcmahon48 Multi-Way 8 15th March 2009 08:06 AM
crossover board exhausted mule Multi-Way 8 22nd January 2009 10:26 PM
Can you check this crossover repair job? silentblackhat Solid State 0 10th November 2008 12:55 AM
Vandersteen 2ci crossover repair olyken Multi-Way 1 27th September 2008 04:00 PM
Circuit board repair suggestions? NewVintageNut Solid State 7 7th January 2008 07:21 AM
Page generated in 0.07224 seconds (75.57% PHP - 24.43% MySQL) with 10 queries
