QWTL and Half WTL in the same BIB cabinet
Old 6th May 2008, 03:49 PM   #1
tizio_82 is offline tizio_82  Italy
Default QWTL and Half WTL in the same BIB cabinet
this is my first post, i'm pleased to write into this amazing forum. My current system is composed by marants CD 6000 OSE (I'd like to upgrade), trends audio 10.1; Triangle Titus 202.
my goal is to buid by myself a speaker able to cover 15K - 45 Hz (in the real world at -0 db) with SPL = 92 db 1W/1m at least
my idea is to use "Bigger Is Better" design with two drivers with active xover:
the first one: fullrange, untill 90 hz using the BIB cabinet design
the second one: woofer or mid woofer from 90 to 45 hz in the same BIB cabinet that will operate as quarter wave transmission line !
the stuffing material will be add empirically
what do you think about it?
is it possible or is just a wired idea?
and what about the drivers?
thanks,
feel free to beat me for my spelling and grammar.
Tiziano
Old 7th May 2008, 03:11 PM   #2
I know, this project doesn't interest the major part of you, the thing is i'm looking for sense of weight and power that lack in my system, and I'd like to been iniziate to diy speaker.
I'll find new ideas.
bye Tizio
Old 7th May 2008, 05:22 PM   #3
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Give people chance. It's the middle of the week.
I can't actually follow what you're trying to say too well. I think you're looking at making a 2 way BIB with a 90Hz XO point. Is that it? No reason why it shouldn't work. BTW -the BIB is technically a horn, not a TL.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 7th May 2008, 09:29 PM   #4
Tubamark is offline Tubamark  United States
If I read correctly, Tizio seeks to use both drivers in the same enclosure/line . . . The line would seem very big to the Fullrange (BIB sized), but the same line will function as a more typically sized TL for the sub driver. I'm not sure where the drivers would be placed to achieve this.
Tizio, am I close? A drawing would really help.
I can't imagine this working well; Either driver could perhaps use the line/horn effectively, but NOT at the same time . . . the displacement created by the sub would prevent the FR from being able to drive the line at all. Your fullrange could even be damaged by pressure in the line from the sub.
Unless someone like Tom Danley is involved . . .
It also seems odd to use a BIB cab for a driver that will not be used below 90 Hz. I would vote to simply put the FR in its own enclosure. Or even no enclosure - open baffle!
Neat idea, though.
--- Mark
Old 8th May 2008, 04:49 AM   #5
GM is offline GM  United States
GM's Avatar
IIRC I've discussed this layout for a BIB, but can't remember in which thread. Anyway, it's based on this rather successful DIY design: http://web.archive.org/web/200705092...io/DIYBX1.html
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
QWTL and Half WTL in the same BIB cabinetHide this!Advertise here!
Half Chang cabinet question JC951t Full Range 0 4th January 2009 03:45 PM
Half Calhoun? Telrab Full Range 11 3rd May 2008 12:40 AM
Half a SoZ? Fuling Pass Labs 9 14th January 2005 11:58 AM
6 And A Half Weeks ? mrfeedback Everything Else 9 27th August 2002 04:16 AM
half -ife human prototype Tubes / Valves 1 31st July 2001 03:27 AM
Copyright ©1999-2017 diyAudio
