how high in the FR does the box Q. affect tonality? i am asking in regards to mids in a three way with most mids running approx. 300hz-5khz. go sealed(at what Q.) or TL.?
blue934 |
#2 |
If i understand your question right, you want to know
what the best Qt for a midrange box is ? If you use a passive highpass for your midrange, there is probably not enough electro mechanical damping, because the midrange does not fully see the amplifier at fr . ( e.g. Midrange builtin fr=120 Hz , 1. Order highpass with crossover frequency = 300 Hz ) In practice Qt should be around 0.6 ... 0.8 . If the system lacks electro mechanical damping via back EMF, you can adjust the mechanical damping by adding flow resistance behind the midrange cone, by placing absorbent material there. Cabinet must be of sufficient size. "Acoustic swamp" or tapered and damped Transmission Line may work fine for a midrange cone, but a sealed cabinet of appropriate size is OK too. The Qt of each system affects tonality. This is valid for Midrange and Tweets as well as the Woofers Qt. I had very good experience with labyrints of foam rubber placed in the midrange cabinets, diffusing the reflexions inside the cabinet. Stuffing too much absorbent material like polyester wadding or wool into the cabinet may tend the sound into "dull" . Cheers Oliver |
#3 |
thanks for the reply. i am more interested in whether the box Q of .5 would have different tonality at say 500hz from a .7 box tuning? at what FR does the box Q not affect the sound anymore?
david |
#4 |
Between Qt 0.5 and 0.7 there will be a significant
difference in frequency response up to 6 x resonance frequency. So if resonance is at 50 Hz, above 300Hz a "steady state" signal (say steady state part of organ pipe sound with fundamental FR of 300 Hz) should sound very similar with both alignments. But music does not consist of steady state signals. In fact both alignments will sound different, not only in bass but also for voices etc. This is why i think a Qt of 0.5 is to low. As far as i remember there has been some research, that Qt lower than 0.6 does not improve performance subjectively, even though a Qt of 0.5 (aperiodic damping) has shortest decay. Hope answer hits better this time ... Cheers Oliver |
#5 |
thanks linearray,
blue934 |
#6 |
Banned
.707 on an appropriate open baffle is hard to beat in 'theory'
#7 | |
crazyhub |
| 3 way using ATC midrange | tech.knockout | Multi-Way | 49 | 30th April 2010 11:04 AM |
| jbl pro midrange | lt cdr data | Multi-Way | 1 | 6th February 2007 07:08 AM |
| Which midrange to go up to 5 KHz? | esl | Multi-Way | 7 | 24th September 2003 01:27 AM |
| Page generated in 0.08132 seconds (79.15% PHP - 20.85% MySQL) with 10 queries |
